Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-14-2010, 07:35 PM   #1
WaldenL's Avatar
Green top vs blue top for covering screws
So I get the difference between green top and blue top compound, green top first for setting the tape. But for covering screws do I need the glue in the green, or do I just use blue?
WaldenL is offline   Reply With Quote
Old 06-15-2010, 04:48 AM   #2
paper hanger and painter
chrisn's Avatar
I really don't think it would make any difference.
Old 06-15-2010, 11:51 AM   #3
they just drywalled 4,000 sq ft here at work and used the green top to cover all the screws with the initial coat and did all the taping with it
BlueBSH is offline   Reply With Quote
Old 06-15-2010, 03:50 PM   #4
Super Moderator
Doesn't make any difference--Most tapers will cover the screws with what's in the pan at the time.
oh'mike is online now   Reply With Quote
Old 06-15-2010, 07:11 PM   #5
WaldenL's Avatar
Great answers. Thanks all!
Old 06-19-2010, 10:18 AM   #6
Drywall contractor
Green lid is perfectly acceptable for all coats when finishing. I personally don't use or recommend lightweight compounds (blue lid) as they don't set up as hard.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 08:08 AM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 09:56 AM
Green is the New Black aaron.klimchuk Green Home Improvement 36 02-17-2009 10:07 AM
Preping green board for tile? stbo2000 Remodeling 9 02-06-2008 10:40 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 06:58 AM
