Got Estimates Today - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 05:16 AM   #16
Rewards Points: 874
Originally Posted by chrisn View Post
Read his post again, carefully. 2 coats hot mud, THEN a coat of regular mud on top, not spackle, ever.
Got it
Mstrlucky74 is offline   Reply With Quote
Old 03-17-2013, 08:11 PM   #17
Rewards Points: 874
spoke to the guy who said it would take two days and he said he would be using another guy and it would take a day and a half total. Is that about right? Thanks
Old 03-18-2013, 05:26 PM   #18
Rewards Points: 874
Sorry to be a PIA ... Gonna make my decision tomorrow. What do you think about my post above and the day and a half
Old 03-18-2013, 06:02 PM   #19
Rewards Points: 528
Just do it. he sounds fine, but then again I am in Utica and I know I could do it in that time frame, except the commute
framer52 is offline   Reply With Quote
Old 03-18-2013, 06:08 PM   #20
DIY staff
Rewards Points: 7,174
It could be done-----but I wonder if it will be dry enough to sand out the next day----
Easy sand ( hot mud) cures to a hard surface in a short time, but the moisture is still there---making sanding the next day difficult if not impossible.
You are there----is this guy good or just fast?
I always use topping mud over the hot mud--and must let it sit for a day before sanding---
There aren't that many sheets,so he could get it done in one day----but if the hole job is done with hot mud, he better be really good with the trowel--that stuff is to hard to sand easily---
Old 03-18-2013, 06:12 PM   #21
Rewards Points: 528
The key Mike is thin coats. Then when it is complete, I use a sponge with lite sanding the next day.
The Following User Says Thank You to framer52 For This Useful Post:
oh'mike (03-18-2013)
Old 03-18-2013, 07:31 PM   #22
Rewards Points: 874
Ok I'm still a little confused about the mud and spackle. One guy told me the job would need (4) buckets of the blue lid spackle/mud and (1) of the green lid buckets. These buckets are NOT mud.
Old 03-18-2013, 08:04 PM   #23
Rewards Points: 5,974
Yes they are that is what people in the business call joint compound. Spackle comes in a little can and is used for small repairs like nail holes or dings.
I don't remember the size of the room but that sounds like a lot of mud. And then throw in bags of hot mud. But he is there looking at it and I am not.
Old 03-18-2013, 08:41 PM   #24
Rewards Points: 874
Ok so on top of he joint compound they should use some bags a hot mud??? Do they mix the joint compound and hot mud? Thanks
Old 03-18-2013, 09:08 PM   #25
NO Joint compound goes on top of hot mud.
[SIE="6"]NO[/SIZE]they do not mix them.
Old 03-18-2013, 09:27 PM   #26
Rewards Points: 874
So is it your opinion that either guy should use both joint compound AND hot mud? Can the job be done with joint compound only?
Old 03-18-2013, 09:40 PM   #27
kwikfishron's Avatar
Rewards Points: 86
Never really have cared much for "some" of these threads where a customer is coming to the internet to micro analyze a contractors methods to reach a result.
"Sometimes" there are a few different ways (all acceptable) to reach the same end result. At the end of the day all you should want are good looking walls in this case.
Checking references and actually going and looking at a contractors past work is a much useful method for you to decide who to hire.
The internet is a wealth of information for sure but many times you're better served by just clicking that little red X and go out, talk to people and look for yourself.
kwikfishron is online now   Reply With Quote
Old 03-19-2013, 06:24 AM   #28
Rewards Points: 874
Your entitled. Just making sure what they are using is acceptable. That is why i asked is using joint compound ONLY was okay. Fair question i think.
Old 03-19-2013, 06:46 AM   #29
DIY staff
The finisher need to use the products and techniques that work for him---
The finished surface is the thing that matters---and there are many ways to achieve a good surface.
Mstrlucky74 (03-19-2013)
Old 03-20-2013, 05:57 AM   #30
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Just let the guy do his job, you do not need to know all the details. If he does not do it right, don't pay him.
The Following User Says Thank You to chrisn For This Useful Post:
Mstrlucky74 (03-20-2013)
Help me understand the huge difference in sewer pipe estimates? thinksincode Plumbing 21 12-18-2012 05:54 PM
Trane XE80 worked yesterday - won't come on today flounder HVAC 29 01-15-2012 12:26 AM
Hot water heater getting VERY hot all of a sudden today bgbrown125 General DIY Discussions 20 12-04-2011 07:04 PM
Plumbing/Elec/Foundation Cost Estimates ACamp Plumbing 7 07-17-2008 01:20 PM
Exterior Painting Estimates...need advice! navi_jen Painting 1 06-23-2008 10:01 PM
