-   -   Got estimates today (http://www.diychatroom.com/f101/got-estimates-today-174662/)
Mstrlucky74 03-16-2013 11:08 AM
Got estimates today
265 Attachment(s)
Two guys came by today. Both will be doing the job by themselves. It is about 40 4x8 boards equally split between walls & ceilings. Both were about the same price but one guy said it will take 2 days and the other said he needed three. I'm sure it doesn't matter but the guy who said it would take three days said he would use a 40" trowel on this one long joint( where the 1st floor meets the 2nd) and the other guy said the longest blade he uses is 10". Just a FYI. Any opinions? Thanks.
joecaption 03-16-2013 11:13 AM
Never heard of anyone using a 40" trowel unless there skim coating the whole wall.
I use a 12" as the last knife on seams, does not make my way right it just works out for me.
oh'mike 03-16-2013 11:23 AM
Three days is typical---two for tape and mud--then a short day for sanding and clean up---
We usually let the mud set up for a day ---so four ,total----
Skill is more important than time-----we often hang and tape ready for sanding in one day---but that's a push job----still looks good---but rarely done--takes a day or two for all that mud to dry.
Mstrlucky74 03-16-2013 11:39 AM
265 Attachment(s)
Don't know who to choose.....any advice
framer52 03-16-2013 12:44 PM
tHE one you are most comfortable with.
40" knife is ridiculous by the way.
have you checked references?
chrisn 03-16-2013 05:26 PM
40" knife is ridiculous by the way.:eek:
no doubt
Mstrlucky74 03-16-2013 05:35 PM
265 Attachment(s)
Originally Posted by chrisn (Post 1138738)
no doubt
He said he was going to use that for one joint where the 1st & 2nd floor meets. He said that is a hard joint/seam to hide. I am just a bit turned off that the other guy said 2 days. And references to me seem bogus....can't someone give you the numbers to family, friends etc. pretending he did work for him?
ToolSeeker 03-16-2013 07:21 PM
Have never heard of 40" knife the biggest I use is a 16" trowel. I think either he misunderstood you or you misunderstood him. And to be real 2 days to tape and mud by 1 guy is doable. It really sounds like he knows what he is doing. He is going to use hot mud for the first 2 coats then sand, then topcoat with regular mud. Just my opinion.
oh'mike 03-16-2013 07:56 PM
Two days is very possible----ask if he has a job going on right now----and would it be possible to drop by the site?
Do not think badly of him if he refuses that----I would never invite someone to one of my jobs without permition of the owner---some customers are very private and that must be respected---
Mstrlucky74 03-16-2013 08:15 PM
265 Attachment(s)
What's hot mud? The first lunatic with the "40" trowel" mentioned hot mud. DOes everyone use hot mud? Maybe I can ask the guy who said "two days" about hot mud to quiz him.....I guess
Mstrlucky74 03-16-2013 08:17 PM
265 Attachment(s)
Thanks Mike!!!!!
ToolSeeker 03-16-2013 08:35 PM
Hot mud is a setting mud it comes in bags marked5 minute 20 minute 45 and 90 and you can get longer. this is mixed with water and the number on the bag is how long it takes it to dry. This is done thru a chemical reaction that is how they can tell how long to dry. Regular drywall mud sets by drying when exposed to the air and can take a day. So by using the hot muds you can get 2 coats on in a day and then sand. The down side is they are hard to sand and finish. So usually the first couple coats are hot mud then a coat of regular mud goes on top or finish coat.
Mstrlucky74 03-16-2013 09:40 PM
265 Attachment(s)
Ok so the mud that you a referring to is different Than that spackle that comes in those 5 gallon buckets? That is the regular drywall mud you mentioned that takes about a day to dry. So there is really no way that the guy who said it would take two days could use the regular drywall spackle? He needs to use the mud that's in the bags? Thanks TS
thatbobguy 03-17-2013 03:56 AM
Maybe the one guy uses a plasterer's darby:
http://www.bontool.com/product1.asp?P=WEDGEDARBY
chrisn 03-17-2013 04:11 AM
Read his post again, carefully. 2 coats hot mud, THEN a coat of regular mud on top, not spackle, ever.
