Good Or Bad Idea To Prime Cementboard? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2014, 11:01 AM   #1
Rewards Points: 152
Good or Bad Idea to Prime Cementboard?
Installing a shower...put in PermaBase cementboard. Is it a good idea, bad idea, or indifferent....to apply a latex paint primer to the cement board before the tile installation?
FWIW..the sides are cementboard....and the ceiling is MR and I primed the MR...just not sure whether or not to prime the cementboard. I will be putting in tile floor, walls, ceiling.
piste is offline   Reply With Quote
Old 01-27-2014, 11:28 AM   #2
Rewards Points: 13,732
It's needs to be water proofed on the face of it in any wet area.(inside the shower area).
A product like Red Gard is used, not any form of paint.
http://www.custombuildingproducts.co...s/redgard.aspx
The Following 2 Users Say Thank You to joecaption For This Useful Post:
oh'mike (01-27-2014), Sir MixAlot (01-27-2014)
Old 01-27-2014, 06:03 PM   #3
Rewards Points: 4,796
That is a bad idea.
jeffnc is offline   Reply With Quote
Old 01-27-2014, 06:07 PM   #4
Rewards Points: 152
Originally Posted by jeffnc View Post
That is a bad idea.
Can u clarify what u r referring to as a bad idea? Latex primer? RedGard? Both?
Old 01-27-2014, 06:18 PM   #5
Primer does 0 to water proof anything. It's porous.
It's made to give a bonding surface for the paint.
Old 01-27-2014, 06:19 PM   #6
I had written more, but somehow it didn't get posted.
RedGard is a fine idea (although I use Kerdi and bypass the use of cement board altogether).
Paint will probably interfere with tile adhesion. That is one of the primary reasons to use cement board. This is not a big deal because you'll probably still have enough grip, but why paint if it can only reduce adhesion?
Also, if it gets wet, mold can grow in there. Mold will not grow on cement board itself though, because there is nothing organic for the mold to eat. Also, if the paint gets wet for an extended period, it can get soft, and the tiles could literally fall off the wall. The thinset will stick to the tile, but there is a layer of mushy paint between that and the cement board.
The Following User Says Thank You to jeffnc For This Useful Post:
joecaption (01-27-2014)
Old 01-28-2014, 01:26 PM   #7
Registered User
Rewards Points: 5,516
"FWIW..the sides are cementboard....and the ceiling is MR"------------ when tiling, some moisture resistant drywall requires 12"oc framing for 1/2" board on ceiling application, and no vapor barrier behind it; http://publicecodes.cyberregs.com/ic...9_7_par016.htm
Gary
waterborne polyurethane on pavers: good idea/bad idea? darb Landscaping & Lawn Care 5 06-21-2013 10:14 PM
good idea to get furnace inspected yearly? Red Squirrel HVAC 12 09-08-2010 11:25 AM
Is using Luan to overlay soffit a good idea? ConstantChange Roofing/Siding 17 10-19-2009 08:48 AM
Creating a hole in the wall to run wires, a good idea? RyanD General DIY Discussions 6 05-19-2009 03:30 PM
Good Idea or Not? PearlWhiteGT Interior Decorating 16 05-15-2009 04:38 PM
