Gluing Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 05:01 PM   #1
Gluing Drywall
Hi All,
I read that you should use an adhesive when installing drywall. However, I'm planning on installing the drywall with screws rather that nails.
If screws are used, is an adhesive still necessary?
Thanks in advance,
Bob
Bob Guercio is offline   Reply With Quote
Old 10-01-2011, 06:51 PM   #2
DIY staff
Rewards Points: 7,174
It's not neccesary--However if you glue you may use fewer screws--making the taping a bit easier--
I seldom use glue----the odor bothers some people ---screws don't smell---problem solved.--Mike---
Old 10-01-2011, 06:56 PM   #3
Rewards Points: 150
Glue reduces the number of nail pops(screws too) that will occur over time. While not necessary we always do it in new construction where settling is more of an issue, and seldom do in older homes. Glue will not reduce the number of screws you need since that is mandated by nationalized code and inspected accordingly.
OhioHomeDoctor is offline   Reply With Quote
Old 10-01-2011, 07:18 PM   #4
Rewards Points: 558
Yeah well I have removed some glued on drywall to repair or replace and itís a pita. Screws are a manís best friend.
epson is offline   Reply With Quote
Old 10-01-2011, 07:31 PM   #5
Rewards Points: 150
Originally Posted by epson
Yeah well I have removed some glued on drywall to repair or replace and it’s a pita. Screws are a man’s best friend.
Well installed material is not designed to be removed easily.
The Following User Says Thank You to OhioHomeDoctor For This Useful Post:
Willie T (10-02-2011)
Old 10-01-2011, 07:32 PM   #6
Rewards Points: 150
Unless your talking auto parts.
Old 10-01-2011, 07:38 PM   #7
Rewards Points: 558
But it sure can be damaged easilyÖ
Old 10-02-2011, 05:23 PM   #8
Registered User
Rewards Points: 5,520
oh'mike is correct, it reduces the number of fasteners. Compare fig.7 with Table 7, just after it; http://gypsum.org/pdf/GA-216-2010.html
Also in 2009 IRC;http://publicecodes.citation.com/ico...002_par010.htm
Check with your local AHJ.
Gary
Old 10-02-2011, 07:00 PM   #9
Rewards Points: 150
Gary
I see the chart but around here the inspector doesnt want to hear well I glued it. Also why would you ever want to minimize fasteners.
Old 10-02-2011, 07:47 PM   #10
Registered User
"Check with your local AHJ." That means authority having jurisdiction---- the Inspector as you well know. Each area is different, check locally.....
We could get into the added strength of gluing vs screwing more but that would be a waste of time, I would think the manufacturer figured in his safety factor where as stated it should hold up adequately. Don't shoot the messenger....
Gary
Old 10-02-2011, 07:53 PM   #11
Rewards Points: 150
Gary
That couldnt be more true about different inspectors requiring different things. It used to drive me nuts when they would say well I interpretate it to mean this..... At this point I am happy to comply with whatever makes them happy. After years of happy compliance the old guys take it easy in us.
Old 10-02-2011, 09:18 PM   #12
Too Old
IMO If you call for a nailing inspection the inspector wants to see the nailing pattern per plan... If you want a glue and nailing inspection then you may want to have a 3rd party inspection if you can. I have never inspected a glue inspection for drywall as an inspector, and as a contractor I have never called for a glue and screw inspection.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-07-2011, 04:54 PM   #13
Drywall contractor
Rewards Points: 1,070
Drywall on wood framing should always be installed with adhesive. Hopefully you'll never have to remove any, but it's worth the "pita" to have a more solid job, fewer "pops", and if you lightly bang the wall with your hand you don't hear the board "rattle" against the studs....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-08-2011, 07:41 PM   #14
Too Old
It sounds to me if you want to spend more time and money then glue and screw. As for less nail pops I can say that all the houses I have built nail pops were never an issue to worry about. Not saying I never had a nail pop but very few, think about what causes a nail pop. I can not say for sure what causes a nail pop but it always seems that a loose nail would be the reason.
Old 10-08-2011, 10:39 PM   #15
Registered User
http://www.paintsource.net/pages/sol...ood_shrink.htm
Gary
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 08:46 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
