Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-06-2013, 09:50 AM   #1
Glue or foam adhesive?
I am drywalling a 1,400 sq ft basement ceiling and walls....
Was talking to someone about adheasive, in the past I used glue tubes, with caulk guns...which ran out fast, hands hurt at the end... annoying...
they said to use adheasive foam with a foam gun like the spray foam people do, just this goes on the studs face instead
anyone use foam adheasive before with drywall? found a few articles on it online, and claims stuff like one can of it can replace 30 cans of normal drywall glue, faster application, no pumping a calk gun... dries in a few hours instead of a day or more...
opinions?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 02-06-2013, 11:32 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
I've never used glue for drywall. Where do you put it?
brockmiera is offline   Reply With Quote
Old 02-06-2013, 11:35 AM   #3
we've always ran adheasive down the joists then put the panel up and screwed it as normal...
the adheasive works as two things... extra support, and stiffens up the wall more, also helps prevent screw pops.... and also works as a bridging medium, so if you have a gap on a stud or it bowes in or something, the adheasive will fill that gap and make it more stable / keep it flat when it dries
Old 02-06-2013, 06:40 PM   #4
A lot of rockers are now using glue on the studs then just a very few screws in the field to hold till glue sets up then going back and removing those screws. Screw perimeter same as always. They say this almost completely does away with screw pops. Now to answer original question No I have never used or heard of anyone using foam.
Old 02-06-2013, 06:49 PM   #5
Only place I've seen foam used is in places that build moduler homes.
I can see it being a mess to work with.
Old 02-06-2013, 08:07 PM   #6
one more thing don't ever use sub floor adhesive for drywall glue. why because in a few months or weeks after you painted you will be sitting in the home and see that it bled through the drywall and mud and primer and paint. and the fix is expensive.
Nailbags is offline   Reply With Quote
Old 02-07-2013, 01:14 AM   #7
Moderator
Good point, Nailbags! Page #2, 2.2.7; http://www.lafarge-na.com/GA-216-07_English.pdf
Somebody is not using the required number of fasteners...lol. pp. 9, Table 7.
Gary
Clothes taking longer to dry?
Carpet over adhesive glue Roses Flooring 1 05-25-2012 10:30 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 06:40 AM
What adhesive to use for EPS rigid foam insulation creamaster Building & Construction 1 04-01-2010 08:00 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
