Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-30-2009, 08:34 AM   #1
Smile
Getting Started Painting/new drywall
I will be helping to paint new construction in basement. New drywall. After reading I know we have to clean/dust the walls, prime the walls and then paint. Question: How long do we have to wait after priming the walls to paint? Just wait until it is dry? One coat primer and then two coats paint seems like the norm. We will be doing the ceilings as well. Again, prime and then paint with a ceiling paint? ANything else I am missing? Thanks
kzag is offline   Reply With Quote
Old 04-30-2009, 08:53 AM   #2
Not all primers are created equal. Apply the primer, and wait the recommended amount of time before applying paint. Just for reference SW Preprite 200 Primer (good for drywall) will dry to touch in 1 hour, but can be recoated after 4 (at 77 degrees F, 50% relative humidity). Know what happens when you try to put more paint on a wall that isn't ready to be recoated yet? The solvent in the coat you are applying destroys the weak bond that the coat below has on the wall, and it comes off!
As for the ceiling, you can use ceiling paint if you want to deal with separate cans. The only benefits are a slight price reduction and a slightly thicker formula to prevent drips. IMHO, it's not worth having to buy extra gallons of paint. You can use the wall paint on the ceiling if you want the same color and sheen.
Ceilings have to be primed, and you can likely use the same primer you used on the walls.
Yep, recommended system on most wall paints is 1 coat primer and 2 coats topcoat.
joenusz is offline   Reply With Quote
Old 04-30-2009, 01:15 PM   #3
Smile
Thanks for the response and tips! This is great! Looks like we are ready to roll!
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 10:57 AM
