Getting A Skim Coat To Stick On Old Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 06:04 PM   #1
j_sun's Avatar
Getting a skim coat to stick on old plaster
Hi,
I have a roughly 3x3 area in my bathroom where layers and layers of paint have peeled off. It has exposed the original plaster finish layer and probably the original lead based paint. I have used a gel based stripper to safely remove the lead paint.
The removed paint has left the area about 1/16" lower than the surrounding un-peeled area. I need to build that out using a few skim coats.
My question is if there is anything I can use other than JC or anything I can do to the JC to make it stick to this plaster/old paint surface better?
The stud space behind the wall where it peeled is where my sewage vent pipe comes from the basement up to the ceiling. I imagine the temperature variations caused by this led to the peeling.
Other than tearing out the plaster and making this a huge project there is little to do to insulate this stud space.
So to account for moisture and temperature variations can I put a coat of bonding primer or other water barrier up first?
I know I kind of jump all over in my questions but I think you see what I am up against.
Any insight or advice will be greatly appreciated!
Thanks.
j_sun is offline   Reply With Quote
Old 05-30-2012, 06:53 PM   #2
DIY staff
Rewards Points: 7,174
Roll on a coat of 'Guards'--that primer should seal the old plaster well enough to allow you to skim coat with joint compound---
Use 'Multi purpose--green lid---that mud contains glue and will give you good results.
As to the moisture behind the wall---there may be cold air entering from the attic--if so ,seal the opening with some great stuff low expanding foam.
I've also seen splits in old iron vents that are as old as yours---Do check that out---Mike---
Old 05-30-2012, 07:28 PM   #3
j_sun's Avatar
Thanks for the advice. Will Zinsser B-I-N primer work as I have a quart of it already?
Old 05-30-2012, 07:35 PM   #4
DIY staff
Yes it will---fine product---
j_sun (05-30-2012)
Old 06-14-2012, 09:52 PM   #5
hboogz's Avatar
Rewards Points: 97
Keeping inline with the OP's Post Tittle --- I'm looking to skim an entryway that hs some old plater that's been painted over plenty of times and has a myriad of cracks and even some hardened bubbles --- what's the best way to attack this>
Scrap the surface with a 4/6" putty knife to try and get the entire surface flat, apply bonding primer, apply skim of joint compound with plater of paris mix using plaster trowel or 10" putty knife ?
Best,
Harry.
hboogz is offline   Reply With Quote
Plaster over Skim Coat Canoe Place Drywall & Plaster 0 08-22-2011 03:13 PM
Primimg over Drywall Skim Coat - Update chisels1 Painting 8 10-12-2010 04:16 PM
PVA Primer Disaster bobcatm Painting 1 08-17-2010 12:41 PM
Skim coat? CNM Design Drywall & Plaster 16 03-10-2010 08:14 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 12:10 PM
