Getting Estimates - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 07:23 PM   #1
Rewards Points: 878
Getting Estimates
Lining up some some estimates to have all my new drywall spackle and taped. Trying to be a smart consumer and wanted to know what I should ask and what answers I should get to make sure I hire someone that does quality work. One guys ad listed level 4 &5. I have never heard of that before. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 03-13-2013, 08:31 PM   #2
Rewards Points: 5,978
Lucky there are 5 level of drywall finish each one better than the last.
http://nationalgypsum.com/resources/...revisiting.htm
Level 5 used to hardly ever be used is residential but in the last few years it has become more popular. And level 5 is not cheap.
Old 03-14-2013, 04:39 AM   #3
Rewards Points: 878
Thanks. Any questions I can ask to confirm/check his quality e.g. How many coats, what type of tape etc.!
Old 03-14-2013, 07:20 AM   #4
I think your best bet would be to ask for references and names of past customers. As far as tape and stuff goes there are a lot out there that you never heard of. And talk to the guy and see what feeling you get.
Old 03-14-2013, 07:42 AM   #5
Rewards Points: 878
Thanks, regarding the tape I meant using mesh as opposed to the solid.
Old 03-14-2013, 04:35 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 494
It is also very , very hard to do properly
The Following User Says Thank You to chrisn For This Useful Post:
Mstrlucky74 (03-14-2013)
Old 03-14-2013, 06:43 PM   #7
Rewards Points: 878
There has to be some tell tale signs that I should not hire one of the people that come to give me an estimate. Example "some of the tape lines might show", " this is only my second time doing this", " I like to put the spackle on first then the tape", " I prefer to use duct tape"...... Really guys ...some advice... I know recommendations are best
Old 03-14-2013, 07:11 PM   #8
DIY staff
Rewards Points: 7,174
Recommendations are the only way----
Drywall taping is like plastic surgery---find the best --that is done by asking Painters----
Or a remodeling contractor that uses a taper.
The last question you will ask is the price--after you find a good taper----
Go to some job sites that are being drywalled----look at the work---ask at your local paint store---
Chat up a pro painter---ask for some names---if the same name keeps coming up---thats your taper.
Here, It's Henry----he's good---I call--he looks at the work--I ask if he's available --then ," How much is this going to cost me?."
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Mstrlucky74 (03-17-2013), ToolSeeker (03-14-2013)
Old 03-14-2013, 08:00 PM   #9
Rewards Points: 14,000
If he so much as mentions spackle or using webbed tape, do not hire them.
Both would not be used by a pro.
Spacle is for filling tiny nail holes nothing else.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Mstrlucky74 (03-14-2013), RTC_wa (03-15-2013)
Old 03-15-2013, 11:47 PM   #10
I would ask were the contractors jobs are were he is working right now go watch him work. talk to prior customers. the bitterness of a poor job out weighs the sweetness of a low bid.
RTC_wa is offline   Reply With Quote
The Following User Says Thank You to RTC_wa For This Useful Post:
Old 03-16-2013, 12:41 AM   #11
Thumbs up
You can look for these things:
  • Make sure the contractor defines you all work that needs to be done and material used in detail (don't forget finishing and post-work cleaning)
  • Ask for estimate time
  • Collect references for jobs that are similar in size and complexity to yours. Ask them about quality of work
  • And don't ask one contractor only, ask quotes from at-least 3-4 contractors and lowest price does not always promise good job.
nisha02 is offline   Reply With Quote
The Following User Says Thank You to nisha02 For This Useful Post:
Old 03-16-2013, 02:01 AM   #12
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
stipple ceilings are so 80/90ish style, go with a modern drywall finished flat ceiling. Around here there are only 2 types of finishing good and bad. 3 coats with sanding in between should be the most all a good taper needs.
ryanh is offline   Reply With Quote
The Following User Says Thank You to ryanh For This Useful Post:
Old 03-17-2013, 02:20 PM   #13
Drywall contractor
Rewards Points: 1,070
As stated above, references and (if possible) look at some of the work. Tape, bed, skim, and sand is normal procedure. If you have any "critical lighting" (a lot of natural sun at a particular time of day or artificial light shining directly on the walls) that will show imperfections, it might be worth paying a bit extra for a level 5 finish. Make sure your guy is willing to come back for touch-up after prime coat. Often minor imperfections are not seen until after a coat of paint.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Help me understand the huge difference in sewer pipe estimates? thinksincode Plumbing 21 12-18-2012 04:54 PM
"How much will it cost?" Asking for price estimates here. AtlanticWBConst. Building & Construction 0 04-22-2012 03:44 PM
HVAC estimates Dale Gribble Off Topic 1 03-26-2012 07:41 PM
Plumbing/Elec/Foundation Cost Estimates ACamp Plumbing 7 07-17-2008 12:20 PM
Driveway paving estimates chandler35 Building & Construction 1 11-04-2005 07:54 AM
