-   -   Getting Drywall up into an attic (http://www.diychatroom.com/f101/getting-drywall-up-into-attic-94087/)
Hunter25 01-31-2011 10:31 AM
I am in the process of finishing my attic and need to bring drywall up there to finish. I am not able to fit it through the stairwell because of the angle. I may however be able to fit it thourgh if I cut all of the pieces into 4' lengths, but this maybe time consuming. I have windows on each side in the attic and was thinking of rigging some sort of a hoist or something to bring them up. does anyone have any ideas? The attic is about 30' up. Thanks
1910NE 01-31-2011 01:11 PM
if your attic windows are big enough, find a lumber yard with a hoist truck (assuming you have not already purchased...)
Thurman 01-31-2011 03:02 PM
Measure the attic stairwell opening to see if the sheet will go straight up. IF there is the 48" needed to go straight up, then remove the attic step springs VERY CAREFULLY, take the linkage apart. This should allow the stairs to hang straight down while folded up. Then IF you're ceiling height in the hall permits, and you're attic height permits, you can hand the sheets up to someone already in the attic.
masterofall 02-01-2011 07:19 PM
A friend of mine just did the same thing except he cut every thing into 2' X 8' sheets to get them through the attic opening. Twice as much tapeing to do. He purchased one of those wallboarders buddies to cut all the sheets in half and said it would of taken him twice as long without it. You must have a large opening if you can get a 4' X 4' sheet up there. Even if yoou can get them up to the window will a 4 X 8 sheet fit through
Gary in WA 02-01-2011 11:13 PM
Is the stairwell of legal size for egress?
Is the width too narrow?
Is the headroom to short?
A picture would help..... Other than a drywall suppliers boom truck, as mentioned.
Gary
CplDevilDog 02-02-2011 05:11 AM
If there is a drywall ceiling below the attic, you can cut a 5' section out between two joists and pass them through. Have the finishers patch the hole while they are there.
bjbatlanta 02-02-2011 02:50 PM
A drywall supply yard will have a boom truck and can stock the board through the window IF it's big enough (48" tall at least). They (or you) can remove the sash and replace after stocking the board. If that doesn't work, I'd opt for handing it up through the floor (as suggested above). Patching the ceiling below will require much less finishing than cutting all of the boards in half....
masterofall 02-02-2011 07:02 PM
except if your boarding the walls you probably have a floor to work on and repairing that could be a pain in the butt with less a than desireable appearance.
bjbatlanta 02-02-2011 07:14 PM
If it's an unfinished attic/bonus room, the floor would be unfinished too, I would assume. Pull up a sheet of plywood, get the board up there, replace the plywood. Put your carpet, laminate, or whatever down and you'll never know the difference....
Jackofall1 02-02-2011 07:36 PM
I would guess that the OP has solved the problem as the original post was 3 days ago and is the only one regarding this subject, don't you just love that, I know I do.
Mark
bjbatlanta 02-02-2011 08:02 PM
You're probably right, but a little more input for someone doing a search of the subject in the future doesn't hurt....
Gary in WA 02-02-2011 08:19 PM
My thoughts exactly! I would answer a post that was two years old and "someone" would say- That post is over two years old! (Like the information for the solution has not changed........) In researching a subject, I often find new information that is 12 years old, but new to me; then I can follow up on the new thought to get proof or today's ideas on it. Very helpful.
Gary
tcleve4911 02-02-2011 09:39 PM
We had this problem on a jobsite and the brilliant drywaller scored the back of the drywall and folded it in half.
Got it up into the space and unfolded and hung.
He made his "folds" on stud layout.
Jackofall1 02-02-2011 10:28 PM
Alright, point taken, didn't mean anything by the observation that the OP appears to have never returned, just an observation, but you gentlement bring to the table a very valid point.
Thank-you for that.
Mark
Hunter25 02-03-2011 06:01 AM
Sorry everyone. got sidetracked with the snow storms. My apologies. Well, I haven't figured out what I am going to do with the dry wall yet. I like both ideas of the boom truck and maybe cutting into smaller pieces. My brother in law suggested rigging a pully system and bring them up through a window but that seem a bit difficult. I am thinking of trying to see if I can get a 6' sheet through the door and then see what happens. I am still a little ways from actually starting the drywall so it maybe another couple of weeks. The insulation is going in next week and then I will start the floor. I am going to rin intot he same problem with the plywood for the flooring as with the dry wall so that will be my test. Thank you everyone for your input and I will post updates as i go. I think this is going to be a long process. Thanks again
