Garage Wall texturing
with the way the mud cured and the temps, I would worry about cracking later on, rather than covering imperfections with texture.. Just sayn', tryin to fix walls with texture on them and trying to match the texture back up later on.....I would not texture them.
take a light around with you once you think you got it right. Just keep working until it is right.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
