Gaps - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 01:22 PM   #1
Gaps
Hi All,
I've finished framing a room in the basement and my next step is drywalling; however, I'm concerned about the evenness of the walls.
I have a six foot spirit level that I used for a straight edge. If I hold it horizontally and press it up against the wall studs, the studs don't line up exactly. Some of the studs are off by almost 1/8th of an inch.
Is this adequate for smooth looking walls?
Thanks in advance,
Bob
Bob Guercio is offline   Reply With Quote
Old 10-15-2011, 01:36 PM   #2
Rewards Points: 150
No, if you throw drywall up on uneven studs at best, you will have "waves" in the drywall and worst case you will crack the board or pull the screw through the board trying to seat it.
I had a few studs out of alignment (which luckily were all set back from the others) so I made small shims to plumb them up.
Good luck!
Jason
stradt03 is offline   Reply With Quote
Old 10-15-2011, 02:36 PM   #3
Good luck!
Jason
Thanks Jason.
It's going to be quite easy for me because I toed the studs in with screws so to move them in or out an eighth of an inch will be a snap.
Thanks again,
Bob
Old 10-15-2011, 02:42 PM   #4
Registered User
Rewards Points: 526
Probably more info than you asked for, others reading may benefit.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Floating corners, primer before and after texturing, etc.: http://gypsum.org/pdf/GA-216-2010.html
Be sure to have required egress in case of fire; http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Fire-block the walls and ceiling. Foam board the rims, air seal the drywall.
http://publicecodes.citation.com/ico...002_par031.htm
http://www.buildingscience.com/docum...-at-rim-joist/
http://www.buildingscience.com/docum...wall-approach/
The studs need to plane all over (hence the shims for the middles), top-bottom-middle. The bottom will really be noticeable if adding base or shoe moulding......
Gary
Old 10-15-2011, 07:39 PM   #5
liscenced electrician
Rewards Points: 538
Tar paper makes a good shin if you need real thin, like where 1/8 paneling is too thick. Just double it up until you get to the right thickness
jimmy21 is offline   Reply With Quote
Old 10-15-2011, 09:09 PM   #6
What is 1/8 paneling?
Bob
Old 10-16-2011, 04:44 PM   #7
Rewards Points: 150
Bob
I'm assuming he means 1/8" paneling.
Old 10-16-2011, 08:58 PM   #8
Missouri Bound's Avatar
Hi All,
Thanks in advance,
Bob
Take your level upstairs and do the same with existing walls. I'd be surprised if you didn't find the same thing. An 1/8" is not something any framing carpenter worry's about.
Old 10-16-2011, 10:29 PM   #9
Too Old
1/8" is nothing. Make sure you check your top plates and at least every 1/3rd of wall. You will notice an 1/8" more on the ceiling corner then you will on the wall.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-17-2011, 11:52 AM   #10
Next Time...New Build
Rewards Points: 150
Obviously too late, but always put the crown on the stud towards you when building the wall. This way you can come back with the planer and even things out.
RickyBobby is offline   Reply With Quote
Gaps in my hardwood floors jpc Flooring 3 06-18-2011 06:08 AM
cutting expansion gaps in underlayment boxy_brown Flooring 6 03-27-2010 04:54 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 11:01 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
