Gap Between New Drywall And Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 10:07 PM   #1
Rewards Points: 29
Gap between new drywall and ceiling
I just built a new closet and am hanging drywall for the first time. Everything went OK but I have about a 1/2" gap between the top edge of the drywall and the ceiling and I am wondering what is the best way to fill that gap? Can I just fill with compound to about the edge of the drywall, then tape, then do normal finishing steps?
Any help is appreciated
acme54321 is offline   Reply With Quote
Old 06-14-2010, 10:10 PM   #2
jlhaslip's Avatar
Rewards Points: 914
fill'er'up
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 06-14-2010, 11:32 PM   #3
Use Drywall Compound
Just fill it with compound , overfill i should say than sand it flush with the drywall than start taping. Its referred by tapers as prefill and most pros will use confill its drys a lot harder than regular compound and hardly losses any volume while drying i wouldn't suggest using this regular compound should be fine
DrunkNinja is offline   Reply With Quote
Old 06-15-2010, 09:23 AM   #4
Rewards Points: 29
Thanks guys, sounds easy enough!
Old 06-17-2010, 10:00 AM   #5
Rewards Points: 150
I would add plaster of paris to the compound. Makes it stronger and shrinks less.
slickgt1 is offline   Reply With Quote
Old 06-17-2010, 11:32 AM   #6
Did you think about putting up some molding? Would be easier then just filling it in and it will look nicer too!
Darien is offline   Reply With Quote
Old 06-19-2010, 09:48 AM   #7
Drywall contractor
Rewards Points: 1,070
Your drywall should have butted to the ceiling. Top sheet is hung first and the bottom is raised off the floor to to butt to the top sheet. The gap is left at the floor. This is more critical on a concrete slab or where water might be an issue (kitchen, bath, etc.) as moisture can "wick" up into the drywall and become a mold issue. If you're confident this will not be an problem, I'd recommend pre-filling with setting type compound prior to taping.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Drywall Corner and Ceiling Skim Coat Rbchound Drywall & Plaster 6 04-29-2010 11:59 AM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 10:11 AM
