Gap Between Drywall And Baseboard - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 08:22 AM   #1
Pardner's Avatar
Gap between drywall and baseboard
Hello all,
New member and first-time home owner. My wife and I just bought a house that needs some work. We hired a contractor for the stuff I didn't want to tackle (bathroom/boiler/plumbing/electrical). The rest I think we can do at our own pace.
In one hallway, the previous owner put up some mirror tiles with double-sided tape. Most of the tiles were cracked.... so down they came. But We discovered a 2" gap between the bottom of the drywall and the baseboard. The gab is only a foot long.
I did a search online for fixes, most results were for caulking between the baseboard and drywall. Any suggestions or links to relative articles?
Pardner is offline   Reply With Quote
Old 07-02-2013, 09:23 AM   #2
Rewards Points: 14,312
Need a picture.
jagans (07-02-2013)
Old 07-02-2013, 09:38 AM   #3
Pardner's Avatar
Will do, but it will have to wait till this evening when I get home.
Old 07-02-2013, 09:47 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 914
Why not pull the baseboard, fill the gap with drywall tape and texture to match?
Old 07-02-2013, 10:09 AM   #5
Pardner's Avatar
(I can see why pictures would help),
The gap is similar to this thread: Best Way to Fill Gap At Bottom?
But my gap comes above the baseboard and it does not run the entire length of the wall. It looks like they used a scrap piece of drywall to finish the wall. The foot wide piece is about 6" above the floor and 2" above the baseboard. I have no idea what is keeping the baseboard from being kicked in (if anything). This section is at an outside corner, the otherside of the corner is covered with a thin fiberboard (not sure what its called) held on by chair guards. So I have no idea if the other side of the corner has the same problem.
Old 07-02-2013, 11:42 AM   #6
Rewards Points: 4,796
A 2" gap is uncaulkable. Stick in a strip of drywall there (use furring strips to attach to existing drywall - Google as needed.) This will need joint tape to patch.
jeffnc is offline   Reply With Quote
How to fix a baseboard heater to drywall with no studs?! gloriousglenn HVAC 9 11-30-2012 09:22 AM
baseboard power outlets amakarevic Electrical 19 09-16-2012 09:32 AM
tile baseboard on drywall or backer board amakarevic Flooring 11 05-20-2011 06:03 PM
Drywall issue at baseboard titan7 Drywall & Plaster 3 02-06-2011 12:30 AM
replace baseboard over damaged drywall nunchion Drywall & Plaster 4 09-10-2010 10:18 AM
