Furnace Room - Ceiling Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 08:43 PM   #1
I am not sure if I should ask this here or in the drywall section. Hopefully I have chosen well.
Over the next few months I will be doing some major work, including HVAC and some plumbing. I need to remove the ceiling in the furnace room to gain access to pipes and ductwork. Are there any risks or dangers in removing the drywall? I plan on replacing it when I am done, but it could be a few months before that happens.
Thanks!
stubits is offline   Reply With Quote
Old 03-07-2010, 08:59 PM   #2
An old Tradesmen
Rewards Points: 7,816
If its not fire rated. No.
Old 03-08-2010, 07:11 AM   #3
I think it is standard drywall. I know that all drywall serves to slow down the spread of fire... and can help control gas and fumes. I don't plan to have fires, gas or fumes, but should I be OK for a few months without drywall up on the furnace room ceiling? The furnace rooms contains the furnace, of course, as well as the hot water heater, both gas, and is located in our finished basement.
Thoughts?
Old 03-08-2010, 03:59 PM   #4
An old Tradesmen
There is no code requiring a residential furnace to have a fire rated ceiling.
Many are installed in both unfinished utility rooms, and basements.
So should be no problem.
Old 03-09-2010, 07:02 AM   #5
Thanks so much! That's what I was thinking, but wanted to confirm before I did anything dangerous.
Thanks!
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 12:39 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
