Fur Down A Celing For Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 09:46 AM   #1
Rewards Points: 20
Fur down a celing for drywall question
I'm finishing my basement and I am getting close to doing the electric. I was going to begin to fur down the celing just enough to clear the conduit that exists currently. My questions are for one Should I run my boards along the base of the floor joists or should I lay my strips accross the joists? And should I wait to do this until after the electric has been run? I guess if I lay the strips accross the joists then I'd still be able to run my conduit but if I go along the the base of the joists then I will have an issue running my conduit later. I"m not sure what the proper way to do this would be?
Also is it ok to go with 2x3x8 boards instead of 2x4? There a little narrower but should provide enough to screw drywall into.
gec5741 is offline   Reply With Quote
Old 05-02-2013, 10:41 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
2x3 should be fine. Going perpendicular to your joists will allow you to shim at the joists more easily so you can get your ceiling perfectly flat.
brockmiera is offline   Reply With Quote
Old 05-03-2013, 10:19 AM   #3
Rewards Points: 2,210
Probably easier to run the electrical lines first.
mae-ling is offline   Reply With Quote
Question regarding speaker/network lines when planning to drywall celing gec5741 Drywall & Plaster 2 04-24-2013 12:05 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
Another raising celing question. bill333 Remodeling 2 01-27-2010 11:08 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
