Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-25-2012, 11:36 AM   #1
Full size brick accent wall
I am putting a full size brick accent wall in the basement we renovated, reutilizing the brick we had removed from the basement.
I have a wood basement now, and am wondering if I should put regular drywall up or something else, if so what?
The wall will be about 20' wide by 8 feet high with a drywall ceiling.
Here is the renovtion if you would like to see it:
http://mcnaughtonbasementrenovation.shutterfly.com/
Any help you can provide would be great.
Thanks.
Lefte
Lefte is offline   Reply With Quote
Old 11-25-2012, 12:46 PM   #2
sdsester's Avatar
Since you are recycling brick and making a wall out of it, I don't see that you gain anything putting drywall behind it. However, I suppose the drywall might serve is a guide to keep your brick wall as square, flush and plumb as the drywall. I doubt that a real mason would use or need such a crutch though.
sdsester is online now   Reply With Quote
Old 11-25-2012, 01:13 PM   #3
Agreed, I am NO real mason, just a DIY'er with a dream trying to keep it's history in this 100+ year old house.
Lefte
Old 11-25-2012, 01:23 PM   #4
automated tool pro
the one wall is an accent wall the rest are being sheetrocked, including the ceiling? Even with a vapor shield, I'd still use a moisture rated board. I get repair calls on a lot of old cantilever's because of drainage issues.
Nice photo album btw. You've been working your butt off
drywallfinisher is offline   Reply With Quote
The Following User Says Thank You to drywallfinisher For This Useful Post:
Lefte (11-25-2012)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
turning a half wall into a full wall lcmakeup Building & Construction 4 01-04-2011 08:22 AM
Garage brick wall repair TANME General Discussion 2 02-04-2010 07:19 AM
Doorway though brick wall. archangel689 Building & Construction 3 04-20-2007 10:23 AM
