Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall
Old 12-12-2008, 10:21 AM   #1
the Musigician
DangerMouse's Avatar
free plans for homemade drywall lift!
ok, i finally got around to this. hope it helps someone save a few bucks!
will answer any assembly questions here if needed. *enjoy*
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
DangerMouse is online now   Reply With Quote
Old 12-18-2008, 07:00 PM   #2
the Musigician
thought i'd add this edited underside shot. be sure to raise the crank higher than shown, and add wheels! sorry....
DM
Old 12-19-2008, 12:33 AM   #3
K&B Remodeler/Tile Guy
angus242's Avatar
Didn't you post this on the contractor site too.....
or did I pick the wrong week to stop sniffing glue?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 12-19-2008, 12:43 AM   #4
angus242's Avatar
can you build your own drywall lift?....done!
I was only partially sniffing glue
Angus
My Albums
Old 12-19-2008, 07:31 AM   #5
the Musigician
that was during construction. this is where the 'plans' are with requested measurements! any other questions should be posted here as well.
DM
Old 01-21-2009, 11:51 AM   #6
how do you keep the legs from not kicking out? I understand how the winch effect forces the center post to rise, but what about the four 4' legs around the center post. How is it that they don't kick out at the middle hinge?
mitaccio is offline   Reply With Quote
Old 01-21-2009, 12:04 PM   #7
the Musigician
they moved a bit on the rise at first, so my son helped steady it until it got within an inch or so of the ceiling, then we rolled it into place and cranked another half turn or two to lock it up nice. i raised the crank to about 2' from floor and screwed in a drawer handle above it to help steady it. i can raise a 4'x8' 5/8" panel by myself now. thanks for your interest
DM
Old 01-21-2009, 01:41 PM   #8
That is some creativity! I like the fact that you invinted something most people can make but personally I would rather spend the money for a cheap drywall lift. If you were to buy all the materials to build your lift roughly around 75 bucks, you can buy a cheap drywall lift for 150 bucks. The drywall lift can be broke down for storage and it's a lot more versitile and user friendly for installing drywall. How big of a footprint does your lift take up when in the down position? I would think about 10' so it wouldn't really work in most smaller rooms. Not putting your design down just in my opinion it is worth the extra 75 bucks to buy a lift made for the job.
ponch37300 is offline   Reply With Quote
Old 01-21-2009, 01:42 PM   #9
excellent. I am in the process of building this. I have 4x8 5/8 sheet I am putting up. I live in a remote area and my 5'6" 100 pound wife is of no help. For the center support, how high up did you put the hinges, and how far apart did you put the hinges on the platform?
Old 01-21-2009, 01:59 PM   #10
the Musigician
12" exactly
they just fall in place, screw them in flat and square.
keep posting if you need more help!
DM
Old 01-21-2009, 02:07 PM   #11
the Musigician
thanks for your comments! in the other threads i explained i had no $$$ for renting or buying one, but i DID have a bunch of 2x4s and hinges laying around.... also had the B&T and rope and steel too! the scarecrow loaned me his brain and i was all set! this was made from stuff laying around many garages and workshops! most people won't need to go buy all new materials to build this. the 10' footyprint is large, but all the rooms here are 12x15 or more, so it's great for me! once it's up in the air, it's only a 6' footyprint. =o)
DM
Old 01-21-2009, 02:20 PM   #12
Danger...I give you much credit for the creativity!
Old 01-21-2009, 02:26 PM   #13
the Musigician
tnkx! necessity may be the mother, but sometimes she's a real bytch.....
DM
Old 01-21-2009, 02:28 PM   #14
Did the caster wheels help to make it more stable when lifting it up? Can I get away with using an eye hook instead of a B&T?
Old 01-21-2009, 03:12 PM   #15
the Musigician
wheels helped a lot, yes.
and i wouldn't.... it would wear the rope. any hardware store will have a couple small b&ts. i used an eye bolt at the first end, though tying it would do the same with a hole and a knot..... the 2 block and tackle pulleys just make it go up so much easier.
DM
More On This Topic
Hi, this is Rich Buccola here in New York City and today of behalf of Expert Village, I'm going to show you how to make sweet potato casserole. It's been about twenty, twenty five minutes. Keep an eye on them. Remember, I told you they're going to be... Read More »
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
How Much Drywall Do I Need?
How Much Drywall Do I Need? by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about calculating materials for drywall. Each sheet of drywall is 4 feet, so I am going to go ahead and measure the length of my wall. The measurement of my wall is 23... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
Hi, this is Christina Varga from the Varga Gallery in Woodstock, New York and on behalf of Expert Village today I’m going to show you how to be a self-taught artist, not an easy thing. All right, going with the theme of unconventional materials and... Read More »
can you build your own drywall lift?....done! DangerMouse Drywall 30 10-04-2009 10:21 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
homemade drywall lift DangerMouse Building & Construction 40 12-07-2008 05:46 PM
drywall lifter - max height rtoni Drywall 20 11-02-2008 09:58 PM
Giving back - Free trellis plans Brik Landscaping & Lawn Care 0 06-27-2008 08:20 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
