Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-18-2011, 10:59 PM   #1
Framing a wall over porcelain tile
I am finishing out a 3 car garage with two bedrooms and a rec room. Since I plan on taking the walls down when the kids go I tiled the floor first. I knew that I couldn't shoot the floor to frame walls without shattering the tile but, I thought that I could drill anchors. Seems like that might have been a bad idea now. I have a 3/16 grout line. I don't suppose it would be possible to use steel base plate with 3/16 or 1/8 screws into the grout to anchor the base plate. The walls are 10ft.
If I have to, I guess I can saw cut the tile to properly anchor the walls. What a shame to cut up my brand new tile work. I'm looking for an option that minimizes damage to the porcelain tile.
Options?
Gentleman Farme is offline   Reply With Quote
Old 03-19-2011, 07:23 AM   #2
Super Moderator
Glue------I have successfully glued the bottom plates using PL 200(?)---read the labels
I've done this several times with no trouble,when finishing basements that have hydronic heating.
The other alternative would be drill and tapcons----I'm not sure which will make a bigger mess.
That glue might be a big job to remove.---Mike--
Old 03-20-2011, 03:10 PM   #3
I found some drill bits that will work for porcelain tile. What size/kind of anchors should I use?
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 02:59 PM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 04:34 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
