Framing A Non-load Bearing Basment Wall (to Be Insulated) - Wood Or Steel? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:02 AM   #1
Framing a non-load bearing basment wall (to be insulated) - Wood or steel?
So I am finishing demoing my basement walls (wood paneling and frame; the old wall was not insulated and was spaced sporadically, and done in 2x3s).
I was planning on doing the new wall in wood 2x4s. However, my brother recommended steel.
I live in southern NY, so insulation is a concern.
1) Will steel reduce the effectiveness of the insulation? If so, are there ways to circumvent this (IE padding the ends of the steel or painting it)
2) Is it easier to put up interior steel vs wood? Is warping less of an issue?
I googled it, and saw conflicting viewpoints with no consensus (http://www.contractortalk.com/f14/st...framing-32191/).
Any input would be very much appreciated.
kuj0317 is offline   Reply With Quote
Old 10-26-2011, 05:07 AM   #2
Thadius856's Avatar
Rewards Points: 504
I don't see any specific reason to use steel over wood in this case. I'd stick to wood framing, unless you can determine why you need the extra cost and headache.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-03-2011, 09:03 AM   #3
Rewards Points: 89
I would go with wood,preferably 2X4 as you can run full size electric boxes in it.fill cavities in with ROXUL R-15,available at Lowes.Vapor barrier (6 mil plastic),then mold resistant drywall at least 1 inch off the floor.
Bearing in mind,bottom plate must be pressure treated,and a capillary break must be under even that,foam insulation strips will do the trick.
Build about 1/4 inch off the wall,and every 10 horizontal feet install a pressure treated stud for a fire break snug against the wall.
spring3100 is offline   Reply With Quote
Old 11-03-2011, 09:54 PM   #4
Thadius856's Avatar
Rewards Points: 504
If it's an interior wall, Roxul makes a highly-rated R0 sound insulator as well.
Old 11-03-2011, 10:54 PM   #5
I would go with wood.
chrisBC is offline   Reply With Quote
Old 11-03-2011, 11:37 PM   #6
for basements we use to use the metal track for the top and bottom plates and just screw 2/4 into them. worked great and we had wood to nail trim to.
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
