-   -   framing ceiling for drywall (http://www.diychatroom.com/f101/framing-ceiling-drywall-75362/)
artlover13060 07-04-2010 08:49 AM
I'm framing my basement ceiling for drywall. I ran new joists perpendicular to the old joists and will run the drywall perpendicular to the new joists. There are soffits on three sides of this room, so in essence I have a tray ceiling. So to my question.... Because of the soffit the long edges of the drywall on the ceiling won't be supported by a ledger board. Is this a problem? Should I add cross pieces between the new joists to fix this? I"m using 5/8" drywall if that makes a difference.
oh'mike 07-04-2010 10:25 AM
If I understood you correctly you should be fine---5/8 DW screwed every 16" will be fine.
Post a picture if you can. Someone will check your blocking and framing for you --if you would like.
----Mike-----
