Fourth Coat? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 11:37 AM   #1
Rewards Points: 948
fourth coat?
This is my first construction project. Framing was bad and hanging the drywall was bad. (Good judgement comes from experience, experience comes from poor judgement, poor judgement comes from lack of experience). So what chance did the mudding have?
After the tape I figured my only chance was to rip it down and start over, but I pressed on.
After the 2nd coat it looked better; I mean, its just a basement and some of the other walls are just blankets of insulation...
After the 3rd coat; it looked better, maybe with a fourth coat...
Assuming there is nothing sacred about 3 coats, do I just put on a fourth coat like the third, or do I sand first?
Toller is offline   Reply With Quote
Old 03-09-2013, 12:05 PM   #2
It's the thickness that counts, not the number of coats. I think you're supposed to keep the mud under 1/4" total thickness but I forgot where I read that. It's up to you whether to sand between coats. Many people just chip off high spots. With that many coats, go easy on smoothing with a wet sponge, if you're doing that, because the more you wet the mud the more you break the bond with the wall.
Dorado is offline   Reply With Quote
Old 03-09-2013, 03:35 PM   #3
People seem to be saying that 1/4" maximum thickness is preferable but you can go up to 1/2".
Old 03-09-2013, 04:45 PM   #4
Rewards Points: 512
do as many coats as needed. 3 coats is the norm for regular new drywall. coating some bad butts can sometimes take 4-5 coats. If its really nasty i would either repair the wall/drywall before mudding. if that is easier said then done then i would tape it then mix up some thick sheetrock 20,45,90. and load the bad joint 1/4" thick. then skim it with my regular regular 2nd,3rd coat mud. 1/2" thick one coat? i think its possible unless you scoop the mud out and just slap it on.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
oh'mike (03-09-2013)
Old 03-09-2013, 04:56 PM   #5
DIY staff
Rewards Points: 7,174
If three coats always worked I would be very happy-----like Prince Lake said---use as many coats as you need to feather out a seam----
Old 03-09-2013, 05:56 PM   #6
I didn't mean 1/2" in one coat. As many coats as you want.
Old 03-09-2013, 08:50 PM   #7
Rewards Points: 512
i've skimmed out some nasty joints that were close to an inch. by the time im done its 8' wide and 6-7 coats later.and i've noticed on some premixed compound boxes that it says you can apply it up to a 1/4" thick. although you will get nasty bubbling. so lay it on thick with the powdered then do thin tight skims with the premix.
Base color coat sticking better then primer? konsole Painting 8 08-22-2012 07:12 AM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 08:48 AM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 07:30 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
