Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-11-2012, 03:23 PM   #1
Folding drywall
I want to build myself a ceiling of drywall and fold the corners 90 degrees.
I have searched google and I can only find the expensive router bit from festool. Can it be done with any router bit as long as it is 90 degrees.
e.g. this one
OOge is offline   Reply With Quote
Old 10-11-2012, 03:28 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Folding drywall
I have no idea what you are trying to do.
You cannot use a wood router bit like that to cut drywall.
Possibly you may be looking for a vinyl trim channel? Example Link Here: http://www.drywallschool.com/bullnose.htm
- Build Well -
Old 10-11-2012, 03:34 PM   #3
sdsester's Avatar
Folding drywall
Are you trying to skip proper taping of the corners?
sdsester is offline   Reply With Quote
Old 10-11-2012, 04:42 PM   #4
Folding drywall
I meant this
Old 10-11-2012, 04:50 PM   #5
Folding drywall
i don't read german. i don't know what folding drywall would gain you.
Old 10-11-2012, 05:21 PM   #6
Folding drywall
You don't have to read german, only watch the photo
I want to make a ceiling like this. (german again, but just look at the pic)
There will be a LED strip around it, that will shine to the ceiling above.
But to prevent seeing all wires and the light source I want to cut and fold it 90 degrees. (indirect lighting).
Old 10-11-2012, 06:20 PM   #7
Folding drywall
Not sure where your coming up with the "fold".
That's a tray ceiling.
Old 10-11-2012, 06:31 PM   #8
bbo
Folding drywall
it looks like its similar.
that said, drywall does tend to chew up bits not specifically made for drywall. i know on my rotary tool the drywall specific bits work much much better and last much longer.
I'd buy the 61$ festool bit.
But only if i was dead set on learning this new skill. i'd probably go thrugh a lot of drywall learning this. much easier to cut a straight line and tape and mud the corners.
bbo is offline   Reply With Quote
Old 10-12-2012, 07:29 AM   #9
Folding drywall
No problem on learning this. Just need to know what is wise to do.
Will the 90 degree folding be stronger than just taping a straight line.
And guess you will see that taping. You don't see the folding.
I don't want to end up in hours of covering the tape and stuff.
Old 10-12-2012, 08:54 AM   #10
bbo
Folding drywall
wise would be tried and true method. if you are into learning new methods and techniques and prepared to redo the work should it prove to be inferior a few years down the road, by all means go to it.
It may show in the future to be superior, but the leading edge is also called the bleeding edge for a reason.
Old 10-13-2012, 09:08 AM   #11
Folding drywall
If I am seeing the photo correctly Trim Tex makes a kit for a tray ceiling and I think it will do what you want.You can go on their website Trim Tex.con and look at it. It is not expensive and is really simple to install. Let us know if this what you mean.
Old 10-13-2012, 04:25 PM   #12
automated tool pro
Folding drywall
It wont work even in theory because you have tray. Where one boards bumps into the other you would still need to finish those joints...use corner bead, tape and mud. good luck
drywallfinisher is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Building & Construction 2 10-28-2011 10:32 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
