Floating Over Painted/textured Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 09:12 AM   #1
Rewards Points: 103
floating over painted/textured drywall
Doing a small bathroom update and instead of taking down all the drywall just to put it back up, I was thinking of just skim coating the current stuff to remove the textured look.
Is there a specific mud to use when doing skim coat, and should I do anything prior to skimming, like TSP or sanding? The current wall is textured drywall with 3-4 layers of unknown paint with latex top layer.
redline9k is offline   Reply With Quote
Old 02-11-2013, 10:18 AM   #2
Rewards Points: 12,812
Not sure how anyone would know without knowing what type texture it is.
Got a picture?
Old 02-11-2013, 10:40 AM   #3
Rewards Points: 103
eh, sorry - its just a basic orange peel....somethin like this;
Old 02-11-2013, 11:23 AM   #4
Have you concidered going over it with 1/4 drywall?
I just hate skim coating.
Old 02-11-2013, 11:32 AM   #5
Rewards Points: 103
I was wanting to go this route because its a 8x5 guest bathroom, so I would be having to mud and tape 2 wall corners, ceiling to wall corners, and joint lines...by that time, id basically have mud on the majority of the wall anyway, so I thought just leaving whats there and floating it might be the better way/and save time?
Are there issues with skim coating over time?
Old 02-12-2013, 08:54 AM   #6
Rewards Points: 5,974
NO NO NO NO NO Even if its only 1/4' drywall nothing will fit or look right window casing, door casing, outlets, switches. Now you have to tape and mud where the wall meets the ceiling, all the drywall seams. If you have one of those medicine cabinets that are flush with the wall it will have to be remounted.
Just rough sand then skim coat I like the ultra lite mud bucket has puke green lid easy to use and sands easy. Use 12" knife to apply, sand down any high spots, fill any low spots, sand lightly, prime, paint, stand back and admire.
Old 02-12-2013, 01:52 PM   #7
Rewards Points: 27
I agree with toolseeker. I recently skimmed an entire bedroom to get the idea of what it takes and I think it would work well for your small bathroom. Just makes sure to thin out the mud...makes it easier to put up. sand it and fill in low spots
woodenSpoon is offline   Reply With Quote
Old 02-13-2013, 10:11 AM   #8
Rewards Points: 2,202
thinned mud applied with a paint roller, then spread with a 12" trowel.
mae-ling is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
