Floating Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 08:13 PM   #1
Rewards Points: 1,062
Question
floating corners
1. should every inside corner be floating, i.e. fasten only one side, which would be the one that holds the other side tucked in? i would say YES but i am asking because the book that i have shows some illustrations that have both sides fastened so i am confused.
2. i know this exceeds the scope of drywall but should the same floating corner rule be applied for cement board that will be used for tile?
Old 05-02-2012, 05:54 PM   #2
Rewards Points: 13,740
Sorry I've never seen anyone "float" an inside corner on a wall.
I have seen where some people float an inside corner at the ceiling. Not sure why.
I feel if anything can move it's going to crack.
Old 05-02-2012, 06:05 PM   #3
Question
that's what my books says. it says that, in a corner, only the panel on one side should be screwed in and the other side should be just tucked it, i.e. held by the other side of the corner.
are you saying that, in such a scenario, both sides in the corner should be screwed in?
Old 05-03-2012, 08:20 PM   #4
Drywall contractor
Rewards Points: 1,070
Don't know who wrote your book, but common practice is to user fasteners on both sides of all corners.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
amakarevic (05-03-2012)
Old 05-03-2012, 09:07 PM   #5
Rewards Points: 2,212
IN some area some are going to using drywall clips, so one corner is fasten to the stud, the other side to the clip.
Just read this article on JLC which is what I think you are talking about. http://www.jlconline.com/cgi-local/v...170a32100a063d
mae-ling is offline   Reply With Quote
Old 05-04-2012, 12:05 AM   #6
Registered User
Rewards Points: 5,516
That looks familiar, LOL. "BY the book" requires fastened corners unless it's not needed for shear value or fire rating= Inside wall corners, 4.9.3-4.9.5 and fig. 5-------- 4.8.2 is one many are not aware of; http://www.lafargenorthamerica.com/G...%20English.pdf
Gary
Tags
drywall , floating corner
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
recommend a book nvr2low Drywall & Plaster 9 12-21-2011 11:37 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Heated underlayment and floating floor for this space? Mid Mo Flooring 0 03-18-2011 11:21 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 05:50 PM
