Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-15-2011, 10:56 PM   #1
Floating Corner
I was reading a drywall book about hanging drywall for the corner of the walls. It said not to screw in the drywall in the corner and have the adjacent wall butt up against it pinching it it. Is there a purpose for this? I always thought you screw the wall in on all the ends. Anyway else use the floating corners?
jburchill is offline   Reply With Quote
Old 06-16-2011, 06:23 AM   #2
KemoSabe
loneframer's Avatar
Floating Corner
The theory is that the corner can move without cracking.
Buildings will move naturally due to changes in humidity, temperature, etc.
By leaving the drywall unfastened, the corner is able to "Float".
I've seen it used on ceilings more than anything.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 06-17-2011, 02:50 PM   #3
Drywall contractor
Floating Corner
I always fasten all corners....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-20-2011, 12:15 AM   #4
Moderator
Floating Corner
Figs. 3, 4, and 5 on page #11: http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
