Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 10-17-2012, 07:06 PM   #1
Float over Topping Compound preps?
Came onto a job where the previous guys skimmed with topping before floating the walls. Since topping compound has no glue and bad bonding properties and I need to float these walls, should I a) coat all the areas with that pink plaster bonding adhesive OR b) simply prime all the walls, float, skim,sand?
woodskill is offline   Reply With Quote
Old 10-17-2012, 08:08 PM   #2
Or fiberglass mesh the whole darn thing?
Old 10-18-2012, 09:15 PM   #3
automated tool pro
Not a lot of reply's?
liability is void here. I'd sand the piss out of it, dust it, dust it with a damp towel and then put a good coat of quality primer on it. wait a couple of days poke your wall with a nail and when you back it out the the adhesion integrity can be viewed. It should pull out without taking paint with it.
drywallfinisher is offline   Reply With Quote
Old 10-18-2012, 11:18 PM   #4
Folks been afraid to touch this one! Thanks for taking a stab at it. Oh how we love sanding, and sanding, and sanding . . .
Tags
float, pink glue, topping compound
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
topping compound types tns1 Drywall & Plaster 5 10-31-2010 01:39 PM
Spackle Properties and favorite topping compound mobiledynamics Drywall & Plaster 0 08-22-2010 09:32 PM
What type of topping compound to use in bathroom? spaceman spif Drywall & Plaster 4 08-15-2010 03:27 PM
