-   -   Float over Topping Compound preps? (http://www.diychatroom.com/f101/float-over-topping-compound-preps-160409/)
woodskill 10-17-2012 07:06 PM
Came onto a job where the previous guys skimmed with topping before floating the walls. Since topping compound has no glue and bad bonding properties and I need to float these walls, should I a) coat all the areas with that pink plaster bonding adhesive OR b) simply prime all the walls, float, skim,sand? :censored:
woodskill 10-17-2012 08:08 PM
Or fiberglass mesh the whole darn thing?
drywallfinisher 10-18-2012 09:15 PM
Not a lot of reply's?
liability is void here. I'd sand the piss out of it, dust it, dust it with a damp towel and then put a good coat of quality primer on it. wait a couple of days poke your wall with a nail and when you back it out the the adhesion integrity can be viewed. It should pull out without taking paint with it.
woodskill 10-18-2012 11:18 PM
Folks been afraid to touch this one! Thanks for taking a stab at it. Oh how we love sanding, and sanding, and sanding . . .
