Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-18-2011, 05:09 PM   #1
Flexible crack filler
Hello all,
I have a 2 foot crack in the drywall that opens and closes based on changing seasons. Tried filling it in with compound but it just cracks again.
I'm not enough of a drywall guy to tape the seam and match the texture so I'm wondering if there is some kind of flexible crack filler that will move with the structure.
Thanks.
Richo is offline   Reply With Quote
Old 11-18-2011, 07:18 PM   #2
Drywall contractor
You can try an acrylic/latex caulk. If the crack isn't that wide it should last a while and is paintable.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Help with adding custom color to wood filler 4thDimension Carpentry 5 10-14-2011 02:46 PM
Cracks in 10 yr old house drywall tenthirtytwo Drywall & Plaster 9 03-16-2011 12:33 AM
Crack in Cast-Iron Wye sonofthetonsured Plumbing 16 01-15-2010 08:10 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 01:07 PM
crack filler CRACKING !!! hellothere123 Building & Construction 3 04-02-2009 10:13 PM
