Flared Corner Bead Issue - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 02:24 PM   #1
Rewards Points: 342
Question
Flared corner bead issue
I have an issue with some corner beads. I have a short area (approx. 5" x 6" X 81") that I have beaded and the bead is flared out (it didn't look that flared when I installed it. So now the panel is concave.
The way I look at it I can either fill in the area with mud or un-install the bead and try to re-seat (PITA).
How best to deal with this situation?
tripower is offline   Reply With Quote
Old 02-28-2010, 05:45 PM   #2
One or the other, or install a bead that is smaller or no bead at all. Most tape on corners are available in smaller or no bead.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-28-2010, 08:33 PM   #3
firehawkmph's Avatar
Rewards Points: 1,898
You can get a bead clinching tool at home depot that comes with a rubber mallet. The tool sits over the corner bead and when you strike it with the mallet, it seats the bead and puts a couple of notches in the bead to hold it to the drywall. You still need to secure the bead. I like using drywall nails for this. The tool isn't very expensive and is actually fun to use.
If you don't want to go that route, use some dry mix mud to fill in the recess. One of the easisand products would work well, 45 or 90.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 12:35 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
