-   -   Flared corner bead issue (http://www.diychatroom.com/f101/flared-corner-bead-issue-65608/)
tripower 02-28-2010 02:24 PM
I have an issue with some corner beads. I have a short area (approx. 5" x 6" X 81") that I have beaded and the bead is flared out (it didn't look that flared when I installed it. So now the panel is concave.
The way I look at it I can either fill in the area with mud or un-install the bead and try to re-seat (PITA).
How best to deal with this situation?
Mop in Hand 02-28-2010 05:45 PM
One or the other, or install a bead that is smaller or no bead at all. Most tape on corners are available in smaller or no bead.
firehawkmph 02-28-2010 08:33 PM
You can get a bead clinching tool at home depot that comes with a rubber mallet. The tool sits over the corner bead and when you strike it with the mallet, it seats the bead and puts a couple of notches in the bead to hold it to the drywall. You still need to secure the bead. I like using drywall nails for this. The tool isn't very expensive and is actually fun to use.
If you don't want to go that route, use some dry mix mud to fill in the recess. One of the easisand products would work well, 45 or 90.
Mike Hawkins:)
