Fixing Texture - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-23-2013, 01:18 AM   #1
Fixing texture
1 of my rooms had failing paint, such as I can pull sheets of it off, in the process of doing that but I then noticed that it looks like the previous owner put a skim coat about 12" wide around the entire room, about 2-3 feet from the ceiling as if to make it smooth for a wallpaper type border around the room.
Some areas are smoother than others but is there a real way to fix that?
toastandjam is offline   Reply With Quote
Old 08-23-2013, 07:58 AM   #2
Rewards Points: 14,026
Got a picture of this texture?
A few choices, remove all the texture, shim coat the whole area to get it flat, or retexture the whole area.
Trying to match any texture is a challenge even for a pro.
Very possible someone painted that area instead of priming first with a real primer.
Just a primer and paint in one would just not work.
Old 08-24-2013, 07:09 PM   #3
Tried to get a photo of the texture but the way the light reflected all the surface, it was hard to see.
Best way to describe it, think of someone taking spackle to fill a nail hole. Well it seems they took the entire contents of the container and spread it 12 inches width across the room.
Old 08-24-2013, 07:17 PM   #4
Gymschu's Avatar
Rewards Points: 942
Bout all you can do is what Joe recommended. Skim coat it with a couple coats of joint compound, sand, remove dust, prime, repaint. They likely ATTEMPTED that where the border was so the border would not telegraph the texture after being applied.
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
Help with texture - any opinions on SW Faux Impressions products Sangiovese Painting 0 10-08-2011 08:10 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 11:57 AM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
