Fixing Outside Corner Bead That Is Cracked, Other Finshing Q's? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 05:40 PM   #1
Fixing outside corner bead that is cracked, other finshing q's?
I have a home that had some pretty "quick" drywall finishing done to it. Some of the outside corner bead is cracked. I don't believe it's because of a lack of fusion because there is no play when you push on it.
What is the easiest way to fix this? I'm OK with just "covering it up" as long as it won't crack immediately afterward. House is around 8 years old so my guess is it's due to settling. BUT not sure if that will work. I was thinking of gouging out around the crack and then filling in with joint compound. Where the crack stops I was going to go horizontal toward the corner as a way of possibly preventing further cracks propagating upward.
Also I have some inside corners that are cracked. Again doesn't appear as though there is a complete lack of fusion only because the rest of the paper still looks decent. Can these be caulked?
Last question. On the trim molding, some of the caulking is cracked and looks bad. We are prepping the walls to be painted and I want to get the best possible finish. Can I just re-caulk the molding? You can see some of the cracked caulking in the picture as well.
Thanks!!
Fixing outside corner bead that is cracked, other finshing q's?-p1050805.jpg
wheelsup is offline   Reply With Quote
Old 04-25-2013, 05:06 PM   #2
Rewards Points: 704
You would have to remove the compound around the crack w/ a metal putty knife, then re-mud, texture, prime and paint.
Though, i'd probably just spackle the crack, prime and paint.
Seattle2k is offline   Reply With Quote
Old 04-25-2013, 05:08 PM   #3
Rewards Points: 704
You already know the answers... Yes, you can run paintable caulk at the inside corners and you can re-caulk the molding.
corner bead question hiding mud line petros151 Drywall & Plaster 9 02-18-2012 07:02 PM
Corner Bead Repair? How? kennykenny Painting 5 01-25-2012 07:55 PM
Corner bead wraiththe Tiling, ceramics, marble 0 12-19-2011 11:37 AM
Tape joint over corner bead? Richo Drywall & Plaster 3 09-25-2011 07:25 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
