"Fixing" Drywalling After Primer? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 12:56 PM   #1
Rewards Points: 980
"Fixing" drywalling after primer?
The continuing saga of my first construction project...
After 6 coats of mud and a good amount of sanding, it looks pretty decent. Maybe not professional, but okay for the basement.
I want to start painting tomorrow. If it is not as good as I think with primer on, can I sand and mud over primer?
BTW, what sort of primer do I need under latex?
Toller is offline   Reply With Quote
Old 03-11-2013, 04:51 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
yes
any quality latex wall primer will do.
personally, I avoid PVA primers
chrisn is online now   Reply With Quote
Old 03-11-2013, 05:53 PM   #3
Rewards Points: 512
i second that. once the primer is good and cured you can skim out any kind of nasties, sand and prime the areas then you can paint wall color once your satisfied.
princelake is offline   Reply With Quote
Old 03-11-2013, 06:42 PM   #4
Rewards Points: 5,974
Yes just remember any touch-up needs re-primed.
Old 03-11-2013, 07:06 PM   #5
funfool's Avatar
Rewards Points: 534
Myself, I would take it all the way through paint. you will see the finished product, paint may make some new boo boo's appear, while some you see in primer may disappear.
Just push forward and paint.
The sheen of the paint, color, texture etc.... will help or magnify issues, will not see them until painted.
Also if you have trim to install or cabinets, you may create a few more dings.
So when all trimmed and painted, walk around with a really good light, use a piece of blue painters tape to mark the areas you want to touch up.
re mud, prime and paint those areas.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
ToolSeeker (03-11-2013)
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
