Fixing Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 06:17 PM   #1
Fixing Drywall
Had a slow leak recently and it damaged drywall I think because the paint has lifted and is now hard. My question is how to repair this. Should I scrape off the lifted paint and then spread drywall compound over it?
Any help would be appreciated.
Thanks, Gary.
gmac111 is offline   Reply With Quote
Old 06-11-2009, 09:39 PM   #2
Rewards Points: 5,336
If the leak has been repaired you can proceed with the interior work. Like you said, scrape off all the loose paint. Skim coat it, prime and paint. If the drywall is discolored or stained, use a stain killer primer.
Ron
Old 06-11-2009, 09:46 PM   #3
Hey , thanx Ron, I fixed the leak 2 weeks ago. Just been waiting to see if there was a slow leak. Doesn't look like it. I'll go ahead and try and fix it with your advice.
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Fixing a bow in drywall DK75 Remodeling 2 05-14-2008 07:14 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
