Fixing Bubbled Facing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 08:41 AM   #1
Fixing bubbled facing
Hello all,
I hope you can help me with my dilemma. I live in a timber frame house that is 10 years old. The frame has shifted and shrunk in spots, a common phenomenon. As a result, the drywall on an interior partition wall has been compressed where it meets a ceiling beam. The paper face of the drywall has "crumpled", or bubbled as a result. The ceiling is 2x tongue and groove pine, so there is no joint where the the wall would normally meet ceiling drywall.
What is the best way to repair this? I believe I need to cut the drywall down just a bit, maybe a 1/4" at most, so it isn't being compressed by the beam anymore, but to do this I'll need to remove the paper facing to below the bubbled portion, about 2" altogether. What is the best way to patch the drywall face afterward? I also have some popped screws because of the drywall movement, but these should be easy to fix.
Llee is offline   Reply With Quote
Old 02-07-2011, 09:34 AM   #2
DIY staff
Rewards Points: 7,174
Cut out all bubbles---Patch with Durrabond--(Bag mix)---That is the hardest of the muds and is commonly used for this purpose--
Use light weight--(blue lid) for the final top coat--Much easier to sand---
Think about adding a trim piece to the top of the wall---That will allow you to leave a nice gap between the DW and the wood ceiling---Mike---
Old 02-07-2011, 02:46 PM   #3
Re: Fixing bubbled facing
Thank you, Mike. Wish me luck.
The Following User Says Thank You to Llee For This Useful Post:
oh'mike (02-08-2011)
Tags
bubbled face , drywall bubbles , drywall damage , drywall repair
Fireplace facing kit welshseahorse Remodeling 3 02-22-2010 01:18 PM
Need Help Fixing My Dresser... changa112 Carpentry 3 04-18-2009 11:35 AM
New to the forum fixing my money pit kell490 Introductions 1 03-30-2009 11:25 PM
Hardiebacker 500 in shower enclosure question (does board facing matter?) DyerWolf General DIY Discussions 3 01-20-2009 06:58 PM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
