Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-05-2012, 02:29 PM   #1
Fixable or gotta replace?
Mother dilemma...is this easy to fix or gotta replace whole drywLl sheet? Was jus thinking tape and mud the gap. It's a 1" Gap FYI.
Aloha1 is offline   Reply With Quote
Old 01-05-2012, 04:06 PM   #2
just prefill..........prefill ...with hard set mud... told you this on three different posts...but if you've never taped before .. might be better to get someone else.
prefill then flat tape it!
but you really gotta know what your doing to mix "hot mud"
later
LR
luckyrabbit is offline   Reply With Quote
Old 01-05-2012, 04:12 PM   #3
Or trim it out with some form of wood molding.
Old 01-05-2012, 08:13 PM   #4
MarginallyQualified
Do over.
Call it a learning experience and growth from the effort of doing something right.
Old 01-05-2012, 08:34 PM   #5
Tileguy
Bud Cline's Avatar
Oh hell! Put a little expanding foam in there and the next day saw it off flush and tape and bed as usual...or get a bigger clock.
Next question?
Old 01-06-2012, 12:24 AM   #6
LOL @bud love the clock comment
Old 01-07-2012, 01:34 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
hi Aloha1, in all seriousness, you can fix this without replacing sheet. I doubt very much if you can pre fill and tape it? as there is nothing to hold the mud to keep if from falling through. short of filling entire cavity.
I'm assuming the wooden beam is to remain exposed? how I've done in the past, is plug patch it. you say it's a 1" gap? I'd cut a 2 1/2" piece of drywall the length of gap from ceiling down to under beam. on the back side of the 2 1/2" piece use sharp knife and score the paper the 1" just the paper! peel paper off, then start scoring gypsum, do slowly until all the gypsum is removed with Spackle knife and only the front paper is left. you want it as smooth as possible, leaving you with 1 1/2" of paper to tape on the plug,
before riding it on, put a piece of duct tape on the beam, down side and bottom of beam, slightly behind drywall line. use a spatula and coat the duct tape with vaseline, the mud wont stick to it much if at all.
then, with your mud, butter it up on all sides of the plug like you would a brick, put a screw in the 2x plate that's showing to help hold the mud. mud all the edges good, place the plug in on an angle, starting against the beam, mud the back of plug enough to allow a bit of mud to slide behind the sheet with gap. mud the sheep with mud enough to set your 1 1/2" paper, use 6" knife to push the plug back into proper position. should make it pretty straight. take you time to make so!
let dry 24 hours at least, finish and feather as needed.
do same with corner bead, leave duct tape in until done and sanded. when all is done, use sharp razor knife, run it along the corners cutting duct tape and remove.
you should end up with a nice clean corner and not a bunch of mud on exposed beam maybe a small bead of caulk
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-07-2012, 02:02 PM   #8
Ironlight's Avatar
I'm with Bud on the foam. I filled a number of drywall gaps in my recent renovation with it and it worked great. I bought it to fill around a new basement window I put in but had 3/4 the can left over so I went to town on the drywall cracks. It cured in an hour and I just sawed it off flat with a jamb saw.
Or...take a furring strip, screw it to the backside of the dry wall with half it's width exposed along the gap, cut a piece of drywall from scrap to fit the gap and screw to the other side of the furring strip, skim with mud
Ironlight is offline   Reply With Quote
Old 01-07-2012, 06:01 PM   #9
good idea Ironlight, but appears other side already closed up? no access for furring strip
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 09:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing 4 02-18-2010 08:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
