Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-25-2012, 10:22 PM   #1
Fix painted mud job
I have a big spot on my bathroom wall that has been mudded and painted. The spot looks like it needs to be sanded. What is the easiest way to fix this considering it's already painted?
Mallard1123 is offline   Reply With Quote
Old 11-25-2012, 10:48 PM   #2
Fix painted mud job
Sand it, prime and repaint.
Old 11-26-2012, 12:02 AM   #3
Fix painted mud job
Can you mud over it and spread it out.
The mud will stick to the paint.
Sand, prime and paint.
masterofall is offline   Reply With Quote
The Following User Says Thank You to masterofall For This Useful Post:
princelake (11-26-2012)
Old 11-26-2012, 08:19 PM   #4
Fix painted mud job
if it was just done then the mud will stick to the paint. when the paint is old and theres a bit of texture to it the fresh mud you put on will bubble becuase it cant adhere to the paint. before mudding the spot prime the area you think where all your mud will go so you know the mud will stick.
princelake is offline   Reply With Quote
Old 12-05-2012, 04:16 PM   #5
Drywall contractor
Fix painted mud job
Sand as best you can (paint doesn't sand well), skim another coat (or three) to smooth it out, sand again and paint. When you skim, a couple of thin coats are better than "piling" the mud on to try to cover with one coat.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Help picking a floor for basement painted concrete erinhall Flooring 1 05-07-2012 05:33 PM
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 07:46 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 09:45 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
