-   -   Fix Bad Skim Coat Job (http://www.diychatroom.com/f101/fix-bad-skim-coat-job-156459/)
smoline 09-10-2012 08:59 PM
Hello -
We just built our new home, and we learned alot. One thing we didn't think twice about was wall texture. Our contractor seemed pretty confident that he was a good drywaller. (We know now that drywall is an art, and he should have subcontracted this out).
It all started with texture. I choose knock down on the ceiling and walls. After he was done and already primed and painted, we notice that we could see lines on the ceilings and the walls were not what knock down should be.
I believe he scrapped while the mud was too wet, leaving long streaks. After we complained, he brought in a person with more experience with drywall and he was told it was the worst texture job they ever seen.
So...the solution was he would hire this outside contractor to skim coat and re-texture the ceiling. I'm very happy with how the ceilings turned out. He then skim coated all the walls and by this time I was so turned off of knock down, I told to just go with orange peel. I'm not at all happy with the walls. After the skim coat and the orange peel texture, you can see faint swipe marks, particularly if you look from a side angle.
We didn't start to notice this until after we moved in and look at the walls everyday, and how different light hits the walls. When you are looking straight at the walls, it's not as noticeable. But, I just can't get past this.
I'm absolutely sick about this. This was supposed to be my dream house and I literally hate walking into this house. What are my options? I've searched the net, and get a variety of solutions....I wonder if I do another coat a paint if it will help?
These streaks are pretty faint. I've seen where you could rent a sander attached to vacuum and sand it off, but other sites are saying skim coat over it! Keep in mind I've already got 2 texture layers, 2 prime layers, and 2 paint layers. Our contractor was over last weekend and says he will send someone to fix this, but I'm wondering if we need to get other opinions. Please help!
DannyT 09-10-2012 10:57 PM
if the contractor is gonna have it fixed have them skim it smooth and be done with it.
chrisn 09-15-2012 04:46 AM
Sounds moe like a bad paint job to me, but hard to say from here. What exactly were the walls primed and painted with, how many coats, what sheen, etc.
ToolSeeker 09-20-2012 08:12 AM
Personally I don"t think smooth walls and knockdown ceiling would look right. Agree sounds like maybe a paint problem. Maybe use a flat wall paint as an undercoat to hide marks then topcoat with a satin or eggshell.
user1007 09-20-2012 03:10 PM
Not sure if NuWal is indicated for something like this or not. Usually I have used it when walls were full of cracks and things. It is a material skin you apply to the wall surface. Not the easiest stuff to work with but put it on your maybe list.
What about some textured wallcovering for that matter? Some of the paintable ones are alright. I just didn't run across them so often anymore.
drtbk4ever 09-20-2012 05:06 PM
Really? Where I live knockdown or texture on walls is seldom seen. Although the odd 70's basement was known to have textured walls.
The majority of homes built in the last 25 years have smooth drywall walls with popcorn or knockdown on the ceilings. The higher end homes go with smooth ceilings too.
ktkelly 09-20-2012 08:32 PM
I've seen more smooth ceilings with texture of some sort on walls for the last several years for the most part.
Especially so in the higher end homes.
HATE popcorn....:mad:
mae-ling 09-20-2012 11:46 PM
See that a lot, looks good
ToolSeeker 09-21-2012 09:36 AM
Must be a regional thing, have seen knockdown on walls and ceiling, popcorn on ceiling orange peel on walls, popcorn on ceiling smooth walls, just don't think I have ever seen knockdown on ceiling with smooth walls.
