-   -   Fix-it-all patching compound (http://www.diychatroom.com/f101/fix-all-patching-compound-102155/)
bluemoonshine 04-19-2011 11:17 PM
Can I use fix-it-all patching compound for filling in and tapeing 3/8'' gaps in the drywall joints? is there something else you might reccomend that doesn't crack/shrink? this would just be for the 1st coat.
user1007 04-19-2011 11:38 PM
How did you end up with 3/8" as a drywall gap. Everywhere or just in a few places?
I would just use mud and lots of it, and just press paper tape in place. There is nothing I know of that is going to keep gaps that size from flexing and potentially turning nasty. I guess you could try the fiberglass mesh tape but I am not sure it will help either.
I hope it is at least nailed or screwed to the 2 by whatevers solidly?
bluemoonshine 04-20-2011 02:22 AM
the plastered wall isnt perfectly square so at one end on the ceiling the gap is 3/8'', I figured i'll just use the mesh tape and the fix it all. should I try and pack a sliver in tightly?
RickyBobby 04-20-2011 08:03 AM
I would use Durabond to fill the cracks first. Apply and let it fully dry, then do your 1st tape coat.
bluemoonshine 04-20-2011 07:12 PM
I went to a small construction store that said they had durabond but they had sheetrock brand lightweight setting-type compound, easy sand, they said its the same but this is sandable which is good, but is it really the same strength? should I use it? this is the same stuff they have at home depot lol, i got the #45.
also just wondering what the differnce is between patching compound and setting type compound? I've used the fix-it-all before to patch plaster and thought it was really strong, its also sandable, it just goes off quick and hard to cleanup.
dberladyn 04-24-2011 12:46 PM
For Pre-Filling gaps/joints you can use anything.
However you are correct in looking for a material that doesn't shrink. The best product to use is a product made by SYNKO called Concrete Fill. It chemically hardens within 30 mins, it doesn't shrink, and it doesn't crack. It actually has strands of fiberglass in the material which give the material excellent structural strength. You still need to apply drywall tape over top, but sometimes people are tempted not to (which is incorrect).
~ A Professional Drywall Finisher.
PS. For repairing Plaster walls, Concrete Fill is almost a necessity. I wouldn't attempt a job without it.
federer 05-21-2014 04:33 AM
where can you buy fix it all locally?
ToolSeeker 05-21-2014 08:37 AM
Have never heard of fix-it-all sounds like a miracle product. Have never used or heard of anyone using concrete fill (but that really doesn't mean anything). But have used tons of Dura bond both the sand able and non-sandable as it is readily available and I haven"t had any problems with it. I would never recommend the non-sandable to a newbie. But situations like this is what these products are for.
ddawg16 05-21-2014 11:13 AM
Home Depot carries it.
I love the stuff....I use it for large holes...doesn't shrink...nice and strong.
mako1 05-21-2014 12:11 PM
I would prefill the gaps with durabond 90 and tape and mud as usual.I would use paper tape on the taping after the prefill.
federer 05-21-2014 02:28 PM
my home depot doesnt sell it...apparently its got asbestos...
mako1 05-21-2014 03:48 PM
HD should carry Durabond 90 or Easy Sand 90.
mako1 05-21-2014 03:50 PM
Dont' get the 20 or 45 thinking you will get the job done sooner.This stuff sets pretty quick for someone with little experience.
ddawg16 05-21-2014 04:29 PM
Really?
Ingredient CAS # Wt. %
Calcium carbonate 1317-65-3 10 - 30
Silica, crystalline, quartz 14808-60-7 1 - 5
http://www.custombuildingproducts.co...S_FixItAll.pdf
I think someone is feeding you a line....oh, wait, your in DC....never mind
Seattle2k 06-06-2014 01:51 AM
Originally Posted by ddawg16 (Post 1353572)
Really?
Someone was likely confused between asbestos and silica. Both are known to cause cancer.
