Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-01-2011, 12:53 PM   #1
Question
First post re sound insulation over drywall
My wife has decided to make the 5 year old Bungalow in the woods into a B&B But there is a noise issue Although the house is new the walls Gyprock had no insulation put in which is normal. I need to insulate between common bedroom walls (IE to avoid my snoring waking the guests ) So was wondering if there is a product out there that can be sprayed in to the walls or a panel that would insulate sound and be glued right to the gyprock and the other dilema is the ceiling of the theatre room same deal cut down the sound to guests rooms above. Easy is best Ripping down and creating baffles will end the B&B idea.
Thanks for your input...
Cheers
WS
Stonz22 is offline   Reply With Quote
Old 05-04-2011, 11:52 PM   #2
http://www.fomofoam.com/Soundproofing.htm
This might help answer some questions
Fantastic is offline   Reply With Quote
Sound Proofing Drywall tigas Building & Construction 7 03-21-2011 07:48 PM
Exterior Drywall Sheathing? Popeye42 Building & Construction 3 01-20-2011 02:20 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Wet Insulation and Drywall jr66 Building & Construction 6 05-06-2007 10:56 AM
