-   -   First post re sound insulation over drywall (http://www.diychatroom.com/f101/first-post-re-sound-insulation-over-drywall-103282/)
Stonz22 05-01-2011 12:53 PM
My wife has decided to make the 5 year old Bungalow in the woods into a B&B But there is a noise issue Although the house is new the walls Gyprock had no insulation put in which is normal. I need to insulate between common bedroom walls (IE to avoid my snoring waking the guests :) ) So was wondering if there is a product out there that can be sprayed in to the walls or a panel that would insulate sound and be glued right to the gyprock and the other dilema is the ceiling of the theatre room same deal cut down the sound to guests rooms above. Easy is best Ripping down and creating baffles will end the B&B idea.
Thanks for your input...
Cheers :wink:
WS
Fantastic 05-04-2011 11:52 PM
http://www.fomofoam.com/Soundproofing.htm
This might help answer some questions
