Firring Old Walls Before Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 10:25 AM   #1
Question
Is there an accepted method to firring old walls (where correction is not feasible) prior to drywall? What to use? The taper varies from 0" to 7/8" over 74" (ht.). Something that will not split? Thank you!!
haddix.steve@gmail.com is offline   Reply With Quote
Old 07-07-2008, 03:37 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, the best method for such a variation is to build a new sleeper wall over the wall itself....if the loss of space is acceptable. Other than that, you generally are going to have to cut each individual stud (16" O.C.)to match the area and to create plumb.
- Build Well -
Old 07-07-2008, 05:49 PM   #3
Registered User
Termite's Avatar
Atlantic's right. I'd suggest building a wall out in front of concrete/block walls that is perfectly plumb.
We have clay and expansive soils around here, which leads to various foundation movement problems. Therefore, I'm never an advocate of fastening furring strips to foundation walls. A 1/2" gap between the stud and the foundation wall gives that foundation a little wiggle room and structurally isolates the basement wall from it. That way every tiny movement your foundation makes doesn't telegraph through your finished wall.
Old 07-25-2008, 04:39 PM   #4
Drywall contractor
Rewards Points: 1,070
Framing a 2"x4" wall also gives you room for necessary plumbing, electrical, and insulation. The only way to do it correctly.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
correct framing , firring , old walls
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall or Denshield behind Shower Walls? atilla137 Plumbing 3 07-20-2008 09:11 AM
installing drywall to 10 ft vertical walls markt59 Building & Construction 6 01-16-2008 07:09 PM
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 07:59 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
