Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-22-2011, 07:08 PM   #1
firing stripes
Do to attach firing strips to poured concrete walls
kebean is offline   Reply With Quote
Old 04-22-2011, 10:41 PM   #2
Drywall contractor
firing stripes
I'd advise framing a 2"x4" wall in front of the poured wall. Much easier to run any necessary wiring, plumbing, etc. Wall will be straighter (unless your concrete form guys were excellent). If you insist on furring (or have no choice for some reason), shoot with a powder actuated tool (gun). I would also use adhesive to be on the safe side. I've had strips turn loose when nailing up the drywall when not glued (someone else did the strips).
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-24-2011, 12:11 PM   #3
firing stripes
Other options:
Glue Styrofoam to the concrete (why have cold walls?), then glue the drywall to the styrofoam.
Or you can directly glue the drywall to the concrete, using concrete nails to tack the sheets while the glue dries.
Personally I would insulate/vapor barrier that concrete wall before installing drywall.
dberladyn is offline   Reply With Quote
Riding Lawnmower, Wrong Firing chainsawmatt Landscaping & Lawn Care 8 02-20-2011 08:49 PM
1979 CJ7 Jeep Not Firing 79jeep Automotive Repairs 0 09-11-2010 12:11 AM
advice on stripes on textured walls la15ota Painting 10 04-05-2009 04:34 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Painting Stripes on Fresh Painted Walls kimmyb Painting 1 02-21-2009 03:48 PM
