Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-26-2009, 07:51 PM   #1
Fire rated drywall between garage and house...on both sides?
So I'm renovation the downstairs and I'm putting up drywall walls against the garage. Currently the garage is finished so I'm assuming the walls in there have fire rated drywall but do the ones inside have to be too?
RyanD is offline   Reply With Quote
Old 06-26-2009, 07:55 PM   #2
Xtreme DIY'r
Is it 5/8" sheetrock in the garage?
That is what is required
I'd do the inside with 5/8" too
Old 06-27-2009, 12:57 AM   #3
inside its not required on single family , multi family i believe it is .
oldrivers is offline   Reply With Quote
Old 06-27-2009, 05:40 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
+ 1
If you are not sure, or if there are more specifics to the situation, just call your local Building Dept. & ask them.
- Build Well -
Old 06-28-2009, 10:48 PM   #5
Renovation Contractor
Paragon's Avatar
Yup it is what is required in your municipality and the inspector would quite happily answer the specific question for you.
Good luck and be safe
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 06-29-2009, 12:52 PM   #6
Moderator
Termite's Avatar
The IRC code requires 1/2" rock on the garage side of the garage walls and any supporting structure (steel posts, stud walls, etc). If there is habitable space above the garage then 5/8" is required on the ceiling and any horizontal members such as steel beams. A lot of people spec 5/8" on the walls but the code does not require it.
In a single family residence under no circumstance should you have to have 5/8" (or 1/2" for that matter) on both sides of the wall separating the garage from the house. Just the garage side. The rock is intended as a fire membrane separation, not a true firewall that is designed to protect the structural elements from both sides of the wall.
Old 06-29-2009, 01:00 PM   #7
It's a finished basement..so I shouldn't finish the inside walls because there is already drywall on the garage side?
Old 06-29-2009, 09:49 PM   #8
Xtreme DIY'r
Do you mean it already has sheetrock up or some other wall cover?
You can put sheetrock up in the basement, just not required for fire code
Attaching garage to house eric haley General Discussion 5 02-26-2009 08:38 AM
Fire Rated Door - Install window? Git Remodeling 10 08-05-2008 04:32 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 05:18 PM
Adding on to house to build a garage. Ohioguy Building & Construction 5 02-09-2008 05:44 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
