Finishing Edges Around Shower - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 10:29 PM   #1
Finishing edges around shower
I'm redoing a bathroom and put in a 4 piece shower (base + 3 wall sections). The walls are direct to stud with flanges on the front and top edges of the wall sections. I put the drywall over the flanges and wondering how to finish the edges of the drywall that meets the shoulder of the shower walls. This is the first time I've done drywall around a shower because I've always done tile in the past, so not familiar with how one would finish off the drywall edges in this case.
I'm thinking of trimming down some outside corner bead on one side the thickness of the drywall and running that along the edge that meets the shower wall shoulder, leaving around a 3/16" gap that would then be caulked once the walls are finished. I can't think of another way to get a clean straight edge that can be caulked.
BOUTYM is offline   Reply With Quote
Old 10-23-2011, 11:10 PM   #2
43 years in construction
Arkitexas's Avatar
There are standard drywall trims already avaiable. One is called an "L" bead , the other a casing bead. Both are designed to trim the edge of a single gypsum board sheet. The "L" bead is applied to the outside face of the drywall and floated out with drywall mud just like a corner bead. The casing bead is installed behind the sheet and wraps the edge of the drywall sheet with a "J" shape that can be floated out or left exposed. Around a tub I recommend using the plastic version to prevent rusting issues.
Rick
Arkitexas is offline   Reply With Quote
Old 10-24-2011, 07:05 AM   #3
Perfect! Thanks.
Old 10-24-2011, 10:24 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
Another method is to leave the drywall short of the flange and fill the gap with a couple lifts of easysand mud. This allows the drywall to sit flush to the studs and not bulge out around the flange.
iminaquagmire is offline   Reply With Quote
Old 10-25-2011, 06:19 AM   #5
I considered this, but on one edge the distance to an outside corner is so small that the valley created by the bulge and the corner bead will be easy to fill. On all other areas the distance is enough that the bulge won't be noticeable.
Old 10-25-2011, 12:02 PM   #6
Arkitexas's Avatar
Although this comment is well intended, it is not a good solution. Such installation may look good at first, but without continuous support along the edge of the gypsum board, I guarantee it will crack.
The surround must be nailed to each stud at the lip. Since you are installing direct-to-stud, install a stud at the vertical edge of the surround to support and nail the surround lip and the gypsum board edge. The gypsum board must always lap over the lip of the surround for support.
Use the plastic "L" bead over the gypsum board edge and nail to the studs. Provide the 3/16" gap between the surround ledge and the "L" bead and float out the edge with mud. Caulk the 3/16" space with silicone sealant.
Rick
Old 10-25-2011, 10:45 PM   #7
Rewards Points: 338
I guess this is just another thing that varies by region. The way I stated is the way I've always seen it done around here. Of course with continuous support for the drywall edge and tape in the mud though. The surround edges get caulked during paint.
Old 10-30-2011, 04:16 PM   #8
Rewards Points: 242
Rick
What he said. Let me add this...at least one manufacturer says to fur out the wall so that the drywall doesn't have to ride up on the lip of the tub surround...but rather slips over the flange...without stress.
That's what I'm going to do. I think they recommended 1/4 inch, but that seems a like a lot. So, fur as your project requires.
My old stud walls were furred out, end to end, top to botom with quarter inch plywood strips on each stud, when I demo'ed my bathroom with its cast iron tub.
Comments / suggestions please, especially if you can recommend something that you have used.
Ed911 is offline   Reply With Quote
Finishing drywall around one piece shower stall jonesbill Drywall & Plaster 5 08-14-2011 09:29 PM
Shower stall installation mforeman1 Flooring 1 04-06-2011 08:39 AM
Bathroom Remodel aworkman General DIY Discussions 17 03-05-2011 02:21 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
