#1 |
Finishing drywall corners on inset "cubbies"
I'm slowly plodding along on my basement renovation. I'm starting to do some drywall work on some inset cubby holes that are going to be drywalled. What would the best way to do the corners be? Basically I assume it's the same as a standard 90 degree corner, except there's 2 horizontal and 2 vertical beads per cubby.
Would the reinforced tape corners be best or the nail on kind with the actual raised metal "bead" be better? |
#2 |
Lic. Builder/GC/Remodeler
My Suggestion: Use metal bead.
- Build Well - |
#3 |
Moderator
I'd use metal corner bead as well. Nail or screw in place. Tape is no good for outside corners...Just for inside corners.
#4 |
Thanks! What's the best way to cut that stuff? Tin snips? Do you "miter" the corners, or just fill in with mud?
#5 |
Moderator
Tin snips are just fine for cutting it. Start from each flange and cut toward the bead.
I wouldn't waste time mitering them. The part that you'd be mitering is buried in mud when everything is said and done. |
#6 |
My suggestion would be to snip the ends of each piece of bead as pictured below. This keeps those edges from protruding. Butt the bead's ends together. Try to measure precisely, but make sure it is not an overly tight fit, or the bead will bow/warp. Whatever gaps below 1/8" show, will usually fill with compound.
Good Luck.
- Build Well - |
#7 |
Aww, you didn't cut that piece just for me Atlantic, did you? LOL
If you did, I'll send you all the dimensions I need and a case of beer and you can do all my cuts. ![]() It'll take me a while to get to that point, but I'm trying to stay a few steps ahead in planning. My next major undertaking after electrical is to fur the ceiling anyway so I can do the rock there, then the walls. |
| Display Modes | |
| Curved corners where drywall meets? | SouthGAreno | Remodeling | 12 | 01-17-2013 04:10 PM |
| Superior Walls - Floating Corners & Drywall | Woodcutter | Drywall & Plaster | 16 | 04-22-2011 01:05 PM |
| Resilient Channels and finishing drywall | Pat the Dad | Building & Construction | 5 | 06-08-2007 09:32 AM |
| Corners with drywall? | Ol' Luke | Building & Construction | 9 | 11-09-2006 07:17 AM |
| drywall finishing | BOP101 | Building & Construction | 3 | 10-07-2006 09:31 PM |
