Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-24-2009, 04:38 PM   #1
LeviDIY's Avatar
Thumbs up
Finishing drywall behind kitchen cabinets
Hi all - New drywall is going up all around the kitchen - In the areas that will be behind cabinets (base and uppers)... how should I be finishing the walls? Regular seam and screw coat mud-coverage?
Also, priming.. I'm going to be using Zinsser 123 to seal/prime the walls... should I bother doing that behind the cabinet areas? I'm sure it couldn't hurt, but in the interest of conserving resources, I wanted to know if that's required, recommended, preferred or not necessary in the least
Thanks!
LeviDIY is offline   Reply With Quote
Old 08-24-2009, 05:00 PM   #2
Moderator
Termite's Avatar
It is pretty normal to mud and tape the walls behind the cabinets just as if the cabinets weren't there. As for primer, that's totally a judgement call. I can't see an advantage of one way over the other.
Tags
drywall, kitchen cabinets, mudding, primer
Hanging Kitchen Cabinets from soffit...no backwall ronp Carpentry 6 12-15-2008 02:45 PM
diy built-in kitchen cabinets Jeremy Hillary Boob, PhD Carpentry 6 11-30-2008 12:46 AM
Type and grade of plywood under kitchen base cabinets? vsheetz Carpentry 5 11-24-2008 05:14 PM
Help on kitchen cabinets derek07 Remodeling 1 03-28-2008 08:00 PM
