Finishing Corner With Two Different Surfaces - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 10:24 PM   #1
finishing corner with two different surfaces
Trying to build a room for the water heater and furnace in the basement. The perimeter walls are cinder block. How do I finish where the drywall meets cinder block?
Thanks !
rygamer is offline   Reply With Quote
Old 09-23-2012, 11:50 PM   #2
Rewards Points: 13,276
May want to concider a trim piece like this.
http://www.imperialgroup.ca/product/...Trim_large.jpg
Then a bead of quaility 50 year paintable caulking.
This would give you a nice finished edge and keep the sheetrock from making contact with the block wall and wicking up moisture.
Old 09-26-2012, 09:38 PM   #3
Rewards Points: 5,974
Trim Tex makes a bead for this very thing if your drywall is 1/2" you need a 1/2" tearaway bead it's very easy to use and you can get it at some big box stores or a local drywall supplier. you can go to trimtex .com to see it. It is great where 2 different surfaces meet. You mud just as you normally would but there is a lip on this bead that keeps your mud from getting on the other surface. When the mud is dry tear off the strip and you have a straight line.
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 04:11 PM
8 x 10 corner loft for 14' wide garage-how to support the corner? Badfish740 Building & Construction 3 10-28-2011 12:35 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
Vinyl Siding Corner Post Obstruction JDPagel Remodeling 4 04-16-2010 01:46 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
