-   -   finishing corner with two different surfaces (http://www.diychatroom.com/f101/finishing-corner-two-different-surfaces-157774/)
rygamer 09-23-2012 10:24 PM
Trying to build a room for the water heater and furnace in the basement. The perimeter walls are cinder block. How do I finish where the drywall meets cinder block?
Thanks !
joecaption 09-23-2012 11:50 PM
May want to concider a trim piece like this.
http://www.imperialgroup.ca/product/...Trim_large.jpg
Then a bead of quaility 50 year paintable caulking.
This would give you a nice finished edge and keep the sheetrock from making contact with the block wall and wicking up moisture.
ToolSeeker 09-26-2012 09:38 PM
Trim Tex makes a bead for this very thing if your drywall is 1/2" you need a 1/2" tearaway bead it's very easy to use and you can get it at some big box stores or a local drywall supplier. you can go to trimtex .com to see it. It is great where 2 different surfaces meet. You mud just as you normally would but there is a lip on this bead that keeps your mud from getting on the other surface. When the mud is dry tear off the strip and you have a straight line.
